585,975 active members*
4,886 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > Dmm Dyn4 pmdx126 ess control build
Page 2 of 3 123
Results 21 to 40 of 47
  1. #21
    Jul 2008
    Re: Dmm Dyn4 pmdx126 ess control build
    Thanks Dan, that helps. Can you tell me if you used the PMDX126 dedicated e-stop relay in your system (relay K2 I think)? Or did you skip that relay entirely and configure mach(3/4) to use a different logic level pinout? If you are wondering why I ask it is because I originally assumed I was going to wire things up like this: (image sourced from the PMDX-126 app notes).
    In the above image it appears that the contactor coil must match the AC voltage sent to the PMDX... From my point of view the only way to use both a 120V contactor coil and the built in estop relay would be to power both the pmdx board and the contactor from the same 120V branch. I could be wrong about this of course.
    I did end up getting the PMDX126/ESS to run the sytem... I'll be testing all of this in a few weeks.
    Again thanks for the info,
    Todd
  2. #22
    Jul 2010
    43
    All I used was the j13 connections gnd and estop which I think preconfigured is port 1 pin 10 in software. But you could use that diagram I did not because I wanted all exterior power to be 24vdc for safety. I powered all components with 240v that would take it. pmdx board, both power supplies, drives.
    Sorry forgot what I did. I did use pmdx k2 relay but ran 24vdc acrossed it to control my relay that has the 120v running through it.
    I would have preferred to just get 24vdc coils on the contactors but that was after I decided to use lower voltage.
  3. #23
    Feb 2016
    13
    LTDan, what size contactor and circuit breaker would you recommend for 3 750w drives on 120v?
  4. #24
    These are 240V drives, not 120V.
  5. #25
    Feb 2016
    13
    • According to the website they are
    • Single/Three-Phase 110~240VAC ± 10% 50/60Hz input
  6. #26
    15362
    Quote Originally Posted by RootbeerFLHX View Post
    That is correct for the Dyna4 Drives
    Mactec54
  7. #27
    So they can be run from 120V single phase?
  8. #28
    Feb 2016
    13
    Yes.
  9. #29
    Jul 2010
    43
    Yes.
    Not sure for 120v. I had wired mine direct and measured the draw then added 10% and used a D curve which allows a 10 times spike for the rectifier and capacitors to charge.
  10. #30
    Feb 2016
    13
    Quote Originally Posted by LtDan View Post
    Ok. When you measured your draw were you running the servo on the machine, or just sitting at idle?
  11. #31
    I found a good deal on EMI filters, if you need any.
    (1pcs) NEW!! SCHAFFNER - FN610-3-06 - POWER LINE FILTER USPP FN610306 | eBay
    He charges $5 shipping for as many as you want. When you purchase, it charges $5 each, but he refunds the extra shipping.
  12. #32
    Jul 2010
    43
    I locked the shaft with an old pulley and a big pipe wrench lol don't try this unless your certain you can hold it. I saw 7.4 amp on 248v then the drive errored. I am using 32amp breaker on 240v for 3 750w drives.
    Fyi I used the dmm drive software to command the motor in test movement mode. You can just do the math and get your answer.
    It is probably gonna be close to double.
  13. #33
    Nov 2017
    83
    Very nice just curious, what model/PN Gould fuse holders did you use?
  14. #34
    Jul 2010
    43
    Hey Ger and mactec I'm having an issue running an atc macros m6start with my system. I can run it on a Fanuc system and Andron but cannot get it to run with my ess for some reason. I'm using mach3 .62 sorry to bother you guys I'm a little stubborn when it comes to asking others for help but....lol
  15. #35
    What macro are you using, and what is the problem?
    Do you have an ATC?
    The default M6Start is not really an ATC macro. If you have an ATC, you'll need to write your own macro, or find one similar to what you need, and modify it to make it work.
  16. #36
    Jul 2010
    43
    Sub Main() 'Define variables
    OldTool = GetOEMDRO (1200)
    x = GetToolChangeStart( 0 )
    y = GetToolChangeStart( 1 )
    z = GetToolChangeStart( 2 )
    a = GetToolChangeStart( 3 )
    b = GetToolChangeStart( 4 )
    c = GetToolChangeStart( 5 )
    tool = GetSelectedTool()
    NewTool = tool
    MaxToolNum = 5 'Maximum number of tools to use.
    ToolDown = -5 'Height for the tool change.
    ToolUp = -0.5 'Height the Z-axis for the tool change.
    PosSec = -0.5 'Safe Position.
    If NewTool = OldTool Then
    Exit Sub
    End If
    While NewTool > MaxToolNum
    NewTool = Question ("Place valid tool number (between 1 y 5)")
    Wend
    Code "G00 G53 Z" & ToolUp 'The z-axis is going to "machine zero"
    While IsMoving()
    Wend
    Code "G53 y" & PosSec 'Going to safe position.
    While IsMoving()
    Wend
    Call MovePos(OldTool) 'Going to the last position to relase the old tool.
    While IsMoving()
    Wend
    Code "G53 Z" & ToolDown 'Down to the height of tools
    While IsMoving()
    Wend
    ActivateSignal(Output6) 'Relase the tool.
    Code "G4 P1.0"
    Code "G53 Z" & ToolUp
    While IsMoving()
    Wend
    Call MovePos(NewTool) 'Go to the new tool position.
    While IsMoving()
    Wend
    Code "G53 Z" & ToolDown 'down the z-axis to hold the tool.
    While IsMoving()
    Wend
    DeActivateSignal(Output6) 'hold the new tool.
    Code "G4 P1.0"
    Code "G53 y" & PosSec 'Returns to the safe position.
    While IsMoving()
    Wend
    Code "G53 Z" & ToolUp 'Returns z-axis to "machine zero".
    Call SetUserDRO (1200,NewTool)
    SetCurrentTool( NewTool )
    End Sub
    Sub MovePos(ByVal ToolNumber As Integer)
    Select Case ToolNumber 'Here set the position of each tool.
    Case Is = 1
    Code "G00 G53 x1.0"
    Code "G00 G53 y5.0"
    Case Is = 2
    Code "G00 G53 x3.0"
    Code "G00 G53 y5.0"
    Case Is = 3
    Code "G00 G53 x5.0"
    Code "G00 G53 y5.0"
    Case Is = 4
    Code "G00 G53 x-1.0"
    Code "G00 G53 y5.0"
    Case Is = 5
    Code "G00 G53 x-3.0"
    Code "G00 G53 y5.0"
    End Select
    End Sub
    Main
    Well if I run this on a machine at work (Fanuc Control it works)
    But cant seem to get it to run with the ess without the ess it works.
    Do I need to use the the macro numbers for the ess like M106 for output 6?
  17. #37
    Do you have Output 5 enabled and configured? It looks like that's the only output this macro is using.
    When you say "Can't get it to run", what is it doing?
  18. #38
    Jul 2010
    43
    And yes finally made a power drawbar.
  19. #39
    Jul 2010
    43
    yep configured ports n pins If i call M6T(tool number) it just dings and does nothing
    sorry had to make the post edit im using output 6 configured as port 2 pin 16
  20. #40
    Jul 2010
    43
    sorry for x2 post
    If I start Mach3 and choose no device or just parr port it runs but when I load ess plugin it does not.
    Ger I figured it out Im sorry to waste your time. I had a conflict with soft limits and G53
Page 2 of 3 123
  1. Mach 3 WITH ESS C62 BOB AND DYN4
    By dynoluc in forum CNC4PC
    Last Post: 11-15-2016, 01:21 AM
  2. DYN4 wiring
    By dynoluc in forum Dmm Technology
    Last Post: 06-05-2016, 03:11 PM
  3. analog control in position mode in dyn4
    By jiuning in forum Dmm Technology
    Last Post: 05-14-2016, 05:02 AM
  4. DMM DYN4 Enable signal.
    By rob2290 in forum Dmm Technology
    Last Post: 06-02-2015, 01:18 AM
  5. anyone with BP boss convert with PMDX126 touch plate
    By hmoore01 in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2014, 08:41 PM
