585,949 active members*
4,131 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Z Axis keeps going to home
    Dec 2005
    134
    Just bought a bed mill with a cent V controller. We loaded a small program off a floppy and it begins to act on the code and then the z keeps going to the home position. We looked at the code and we are not seeing what is causing it. Is there anything I missed in the setup parameters that may be causing this?
    Joe
    Jun 2010
    119
    Re: Z Axis keeps going to home
    Can you post the section of code where that happens?
    Sent from my LG-H830 using Tapatalk
    Apr 2005
    6
    I once mistyped the tool change position parameter as a positive number when it should have been negative. A tool change just ran it to the upper limit and stopped. Other than that, make sure you understand the tool offsets. Zero position is at the top. Without some negative numbers in the tool offsets or coordinate settings any positive z number will run the head to the top limit.
    Dec 2005
    134
    We had a wrong H value - thanks. Everything is good again.
  1. So, how does one home a 4 axis CNC?
    By subnoize in forum Benchtop Machines
    Last Post: 06-09-2013, 05:46 AM
  2. Home Brew 4th Axis
    By Bob Jr in forum WoodWorking Topics
    Last Post: 05-17-2012, 02:58 PM
  3. SERVO LAG EXCESS Y AXIS (Y axis won't home)
    By eltorio in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-19-2011, 01:10 PM
  4. Z-axis home
    By gracemach in forum Fadal
    Last Post: 05-02-2011, 10:48 PM
  5. How do you home an A axis?
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 09-23-2009, 01:22 AM
