585,997 active members*
4,844 visitors online*
    Feb 2007
    Unhappy RS 232 communication using LABview for modem
    hye..i'm a newcomer here and i really need this community help. i'm learning how to communicate with RS 232 modem.how to get the data from RS232 modem...i'm using LAbview basic serial read and write VI. i'm using the AT command but the reponse is the same as the AT command..how to convert the data we get from the modem to the info that we want which is i want the info about the modem..
    Sep 2014
    Re: RS 232 communication using LABview for modem
    hi my firend
    if you want use labview for comenionation with another thing you should :
    1- install labview
    2- install real time
    if you want continuance i can help you
    Dec 2005
    594
    I hope he figured it out. His post was from seven years ago.
  1. Pinouts for 9p to 25p No null modem
    By EliteCustoms in forum Fadal
    Last Post: 08-02-2010, 02:03 PM
  2. hw allow Mach and Labview to drive a mill?
    By wddanie in forum Machines running Mach Software
    Last Post: 03-28-2007, 07:16 PM
  3. VIs to allow Labview to drive the G-Rex?
    By wddanie in forum Gecko Drives
    Last Post: 03-11-2007, 08:08 PM
  4. Have High Speed Modem, and Dial up Using Router
    By tobyaxis in forum Computers / Desktops / Networking
    Last Post: 07-24-2006, 03:17 AM
  5. Null Modem Question
    By bz1801 in forum DNC Problems and Solutions
    Last Post: 02-21-2006, 03:20 PM
