585,719 active members*
4,431 visitors online*
IndustryArena Forum > Community Club House > Environmental / Alternate Energy > How Does CNC Routing Compare to Traditional Powertools Ecologically
Results 1 to 6 of 6
    Nov 2016
    I got to thinking about routers.....
    In the "old" days, you'd use a pantograph....
    But manual or CNC, one aspect that throws the perspective is that a CNC spindle and axis control eats power....but pumps out the product!
    A manual machine, on the other hand, may use less power, BUT, you have to run it a lot longer for the same toolpath.
    ... And my coffee consumption tripled when I started running CNC.... so you have to factor in the pot wattage, extra trips to the store for beans...
    Feb 2006
    210
    Had a bit of trouble sleeping there, did we adamjohn?
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Apr 2004
    5734
    Re: How Does CNC Routing Compare to Traditional Powertools Ecologically
    So if you can make more products out of wood in a shorter amount of time, is that worse for the planet? If that's the case, then is any increase in productivity a bad thing, ecologically speaking? If you're powering your router with solar panels and cutting recycled materials, does that make it okay?
    Andrew Werby
    Website
    Apr 2007
    1955
    One way to look at it is the total cycle involved to make something. Take for example making a 24 x 24 inch "door", with internal carvings and some kind of decorative edge.
    If you did this with traditional tools, it would take conventional cutting, then routing, then several steps of sanding, all creating a lot of dust and using power.
    With a very solid CNC, you can do the entire project and most of the fine detail very accurately, greatly reducing the power and dust related to sanding.
    It also has the potential to reduce transportation related pollution, as items made locally with CNC compete against items made overseas and shipped to you. A tree grown and turned into a table represents fixed carbon, so if you are into carbon counting, a person could argue that we improve the world by building things out of wood.
    What many woodworkers consider to be traditional tools, don't use any power at all.
    Nov 2016
    28
    A cnc can also be used to make tools, templates, jigs, and fixtures to speed up the process of traditional woodworking.
  1. EdM cheaper than traditional machining?
    By nadsab in forum EDM Discussion General Topics
    Last Post: 07-01-2012, 01:49 AM
  2. Cutting Aluminium ecologically
    By spaltiel in forum DIY CNC Router Table Machines
    Last Post: 02-24-2012, 02:32 AM
  3. How Does CNC Routing Compare to Traditional Powertools Ecologically?
    By marklavin in forum Environmental / Alternate Energy
    Last Post: 11-05-2011, 01:51 AM
  4. emc2 for traditional chinese
    By ktchk in forum LinuxCNC (formerly EMC2)
    Last Post: 06-26-2011, 11:34 AM
  5. reverse traditional application
    By JEST in forum Linear and Rotary Motion
    Last Post: 05-06-2011, 09:13 PM
