585,702 active members*
4,161 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How to set a large tool?
    Nov 2016
    Hi experts,
    I am struggling to regiester a large tool in ATC in RANDOM system.
    I'd like to set a large tool between dummy tools.
    Machine is OKUMA HOWA Millac 1052v
    Control is OSP-HMU
    On ATC POT NO. / TOOL NO. TABLE screen,
    I tried S_7,L for a large tool on ATC POT NO. / TOOL NO. TABLE screen.
    but syntax error returned.
    S_D for a dummy does not work either.
    I am not sure even above setting for a large tool is correct in OSP-HMU
    Thank you in advance.
    Jun 2015
    4154
    Re: How to set a large tool?
    I tried S_7,L for a large tool on ATC POT NO. / TOOL NO. TABLE screen but syntax error returned
    hy, what i will say is from an osp300; hope this procedure is similar with yours
    If with "ATC POT NO. / TOOL NO. TABLE" you reffer to same location, than this location is related to a register, where you can define a lot of data for each tool, including " L ( heavy ) " atribute. This register should be accesed from same page where "ATC POT NO. / TOOL NO. TABLE" is, but from a different tab.
    Setting " L ( heavy ) " requires neighbour pots to be empty, so to auto-assign them the " D ( dummy ) " atribute.
    If with "ATC POT NO. / TOOL NO. TABLE" you reffer to same location > this location should not allow you to declare more tools than magazine capacity
    This location links to a tool register, that may contain much more tools than the magazine capacity ; i think you must find & edit this register, and after just link the new field to "ATC POT NO. / TOOL NO. TABLE" location / kindly !
    Jun 2015
    4154
    please check attachement for a heavy tool, VATLB[4]=1 ; you may check this once the tool is in the spindle, because it works only for active tool
    i just checked on the machine : variable is read-only / whatever
    Dec 2008
    3108
    Quote Originally Posted by gtkim View Post
    The underscore is a SPACE not [ _ ]
    & it must be done on the "Pot # to Tool #" page.........not the "Tool # to Pot #" page
    If you are in the habit of removing all tools at the end of each job.... there is a command to CLEAR all the pots of the tool #s <TCAN>, and also a command to set the tool #s to match the pot #s <TSET> .....this is up to OSP7000-M, & maybe up to the U100M
    - this is handy if you have dedicated tools and also load tool lengths & diameters using a separate tool length & diameter file
  1. Replies: 7
    Last Post: 01-10-2016, 02:33 PM
  2. Large tool designation
    By Gookinhimer in forum Haas Mills
    Last Post: 03-09-2015, 12:22 AM
  3. Removing large amounts of material fast in d2 tool steel
    By jimmyjames1981 in forum Material Machining Solutions
    Last Post: 09-11-2014, 05:29 AM
  4. how to turn off Large tool option in haas VMC
    By dingo0722 in forum Haas Mills
    Last Post: 09-20-2013, 04:05 PM
  5. Tool not large enough to face off part (9.1)
    By Berlioz in forum Mastercam
    Last Post: 01-21-2012, 11:51 PM
