585,991 active members*
6,427 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How hard would these connectors be to find?
Results 1 to 7 of 7
    Jun 2013
    19
    I might be picking these up and was wondering if anybody could recognize the connector from a poor photo. They do not come with wires and I wonder how much of an issue that would be? pardon the poor photo it is all I have.
    http://i.imgur.com/uT8BmJw.png
    Mar 2016
    325
    Re: How hard would these connectors be to find?
    You can find it or replace it with whateve You like. Usually connectors are similar in most servomotors, but may be slightly different depending on controller. So You can surently identify it if You find info about motor and controller, but sometimes it's Just easier to replace them with watever You find.
    Nov 2012
    1267
    Those are MIL-C connectors, should be very easy to find. Just have to measure them and figure out exactly what type they are. They would be pretty expensive if you buy new, so go to DigiKey to identify the connectors, then look on eBay for some old stock and surplus.
    Apr 2005
    1268
    Try looking for amphenol (spelling???) connectors.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    May 2015
    1422
    Spelling is correct Bill, we use Amphenol at work all the time. Also note that each socket is on a mounting plate (you can see the four corner screws for each on the photo) so, if it comes to it, you could also find mating pairs of whatever connector about the same size and replace them on the drive as well as the cable.
    Nov 2012
    1267
    Amphenol is just one of the companies making those connectors. "MIL-C" (or "MIL-DTL" as they are called now) would be a more general search term.
    Jan 2006
    11
    As others have stated above, these connectors are pretty standard and can definitely be obtained new (Mouser, Digikey, etc.) or on ebay. One of the many nice things about these connectors is that they are stamped with their complete part number on the edge of the square mounting plate. Depending on your eyes you may need a magnifying glass to make out the numbers exactly, but then just type them into the Mouser or Digikey search engine and they will normally pop up with the exact connector. You don't want that connector, you want the mating one. But the string of information in the search result will include the shell size, and from there I've had excellent luck searching with the shell size, the product series, number of pins, etc. to arrive at a part number for the mating connector.
    Dave
  1. Where to buy hard to find tools
    By J S Machine in forum Tormach Personal CNC Mill
    Last Post: 01-08-2016, 06:27 PM
  2. Why are Korean components so hard to find in the US?
    By RBrandes in forum Hyundai Kia
    Last Post: 07-25-2013, 11:06 AM
  3. Looking for a hinge that is hard to find
    By NTUU-KPI in forum Want To Buy...Need help!
    Last Post: 05-31-2010, 04:07 PM
  4. Why is it getting so hard to find a great cnc programmer?
    By jimreed in forum Employment Opportunity
    Last Post: 01-16-2007, 08:25 PM
  5. Where can a guy find cheap mil-spec connectors?
    By damae in forum Servo Motors / Drives
    Last Post: 07-31-2005, 04:32 AM
