Originally Posted by
seapacer2
Hello All,
I have a 3-axis Anilam Crusader M on a Bridgeport Series 1 which to be fair for
its age is a tremendous machine in terms of functionality and accuracy. However
it has limited memory and over time it has become less reliable. I currently
utilize 3 axis and a cad/cam software for programming via RS232.
I'm considering upgrading the controller either to a PC based controller (Mach 3) or
upgraded controller. I'm open to recommendations and looking for what other people
have done, I'm sure I'm not the only one that has done this before.
I'm basically after any thoughts on how I should go about this. I'm guessing using
PC based software such as Mach 3 I can then communicate with the servo drives
which in turns controls the servo motors based on input into the PC from the glass
scales? However, I'm unsure as how to go about linking the lot together. Do I need
some form of PCI extension card to communicate between the servo amps,
scales and limit switches etc.? Or is this done via serial communication to another
circuit board which controls the hardware? Will I need any additional software?
Ideally I would like to stick to using my original drives if possible and ball screws,
along with as many hard parts and components as possible to keep this conversion
to a minimum.
What systems does everyone recommend and do you have a list of the components that it will
take to do this retrofit?
Thanks, Mark
