584,833 active members*
5,695 visitors online*
Results 1 to 8 of 8
    Dec 2016
    Laser Engraver wont Engrave!
    Hello, first time posting reaching out for help! I have a Hurricane (chinese) 60 w laser machine. It has been humming along great but now has a problem I can't fix. When I send it an engraving project and hit start, it moves to the bottom extent of the Y axis (vertical) of the project, and then it moves quickly in a straight line up wards to the top extent of the y axis of the project. It doesn't make passes side to side. If you send it different sizes of projects it knows the new extents of the top and bottom, but just wont make passes to engrave.
    I don't know if I am explaining this well enough, I hope I am.
    The funny thing is that if I load an old saved project, it engraves it fine. The only problem is if I send it something new. Cutting works fine.
    Any Ideas?
    Aug 2015
    52
    Re: Laser Engraver wont Engrave!
    you can try to connect it to computer with usb cable (if your system is RD ),then use the computer to start working. hope can help you . my advise you can upload a picture of the control panel,so we can check the system.
    Web:Jinan Blue Elephant CNC Machinery Co.,Ltd.
    Whatsapp/mobile:0086-15064026772
    Email: [email protected]
    Jan 2017
    I believe I am experiencing the exact same. Might you have found a solution? I made the following video of the issue in action
    https://www.youtube.com/watch?v=-4uOOaAG2_I
    -R
    Quote Originally Posted by LazerDave View Post
    Any Ideas?
    Nov 2005
    11
    Any Ideas?
    Have you resolved the problem? i am having the same and EXACT problem!
    awaits for the answer!
    regards
    rick
    Nov 2005
    11
    Well i will reply myself for someone future´s reference.
    In: system settings -> Advanced Functions uncheck the enable from rotate engrave! thats all!
    regards
    rick
    Nov 2012
    145
    I was thinking writers block!
    Nov 2005
    11
    Quote Originally Posted by tom o View Post
    really i dont understand what do you are saying, could you explain please
    regards
    rck
    Aug 2018
    28
    Thank you Flor for your tip!
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
  1. Laser cutter wont cut/engrave
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-14-2013, 01:26 AM
  2. My laser engrave wont trace objects, only cuts using horizontal or Vertical paths
    By ElationArt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-15-2012, 01:18 PM
  3. Looking for engraver to engrave on OD
    By laka in forum Engraving Machines
    Last Post: 11-16-2009, 07:14 PM
  4. looking for laser engraver to engrave traffolyte
    By dougdv in forum Want To Buy...Need help!
    Last Post: 06-04-2008, 03:28 PM
