585,991 active members*
5,740 visitors online*
    Aug 2015
    37
    consistent motion problem
    Hi...I have a problem that if z is moved up, then xy moves in positive direction ..the xy looses steps....if then z is moved down, xy in same direction works fine....breakout board?....how do I test ... mach 3
    May 2005
    1397
    Re: consistent motion problem
    Shielding on wires? Add a counter weight to Z so it is easier to lift... Z drive may be sacking power from X y?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    1943
    Star type power distribution, out Daisy chained?
    Sent from my Z958 using Tapatalk
  1. Chinese 40w laser power output not consistent
    By kwiktsi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2017, 05:57 PM
  2. X & Y Motion Problem C-10 BOB
    By pianori in forum Open Source CNC Machine Designs
    Last Post: 05-24-2016, 01:44 AM
  3. making thrust washers - parting off not consistent
    By pmurdock in forum MetalWork Discussion
    Last Post: 02-12-2010, 06:52 PM
  4. Tool Height not consistent - Meldas M50
    By avongil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-12-2008, 09:38 PM
  5. Help! Consistent Gecko Fault or Servo Stall
    By Noah in forum Gecko Drives
    Last Post: 06-30-2004, 04:48 PM
