585,954 active members*
4,559 visitors online*
    Jan 2014
    27
    4th axis question
    Hello
    can someone please help me ?
    I am buying this 4th axis for my cnc machine CNC F Style A-Axis 4th-Axis Router Rotational Rotary Axis 3-Jaw 80mm+Tailstock | eBay and wanted to know can I also use it on my laser machine which has leeto controller that supports 4 th axis ?
    I honestly don't see why it shouldn't work given that the motors are almost identical but seller says it's not possible that it's for cnc machine. Maybe she's right but I would like to be certain
    Can someone please clarify this ?
    Thank you in advance
    Aug 2006
    16
    Provided your stepper driver can run the motor from their description:
    NEMA23 stepper motor, 1.8degree, 2.2N.M 3.5A
    Can't see why not.
    What stepper driver have you got?
    Jan 2014
    27
    Re: 4th axis question
    Where can I see that ?
    I asked seller, still waiting for reply
    I know it has 3 phase stepper, is that it ?
    Aug 2006
    16
    You already have a machine yes?
    What stepper driver is fitted to the machine that you want to use to operate the rotary?
    You need to look at your machine.
    Jan 2014
    27
    To be honest I'm not entirely sure where to look for the stepper driver
    I already asked seller, should have the answer tonight
  1. VF4-SS A-Axis Question
    By tcovington in forum Haas Mills
    Last Post: 04-25-2016, 02:39 PM
  2. Y-Axis / Z-Axis Bearing Setup Question
    By KittyPants in forum DIY CNC Router Table Machines
    Last Post: 08-22-2013, 10:45 AM
  3. 4th Axis Question
    By MetalShavings in forum Tormach Personal CNC Mill
    Last Post: 02-14-2013, 12:33 AM
  4. Rookie Question...3 axis vs 4 axis controller
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:04 AM
  5. AXIS QUESTION
    By bbrown2005 in forum Mach Mill
    Last Post: 04-07-2008, 05:43 PM
