Originally Posted by
SG50
A friendy warning..do not test/operate control box without a load (meaning the router's x,y,z cables must be connected to machine) or you risk damaging the driver board.
As stated before..mach3 needs it's own pp driver and not any other.Best to uninstall and reinstall mach3 with driver amd then reboot as instructed. The fact that xdr,ydr,zdr lights go on /off means signals are getting through although you said no xyz movement. Is the Estop
button released instead of pushed in? Twist and turn to release.Use desktop with XP..it's more likely to run. Also toggle reset in mach3 screen to get out of Estop blinking.Only then can you try jogging the x,y,z axis.
Check if "enable" signal is defined in output signals tab.Same with Estop.
Multimeter will not read at motor outputs as the speed/frequency is too high..readings will fluctuate. Mach3 demo version defaults to 25khz. frequency. Multimeter will at best do a few kilohertz.So you will need to plug in the machine.Also if no gcode is running there will be no output signals at the motors.
