585,749 active members*
3,872 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > I need help making a digital scanned .igs part turned in to a solid .igs
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Mar 2008
    683
    Quote Originally Posted by poolrod2 View Post
    I have a trial version of Rhino now, but still don't know how to turn my scanned 3d model into a solid. Thank you all for your efforts so far.
    As we have said. IT IS a solid. You can use it as any other solid in solidworks. Trim your corner off and the offending geometry will vanish. You tabs can be added with extruded sketches.
    If you want this recreated without the surface patch and don't know how I am a professional designer and design guitar necks and bodies all day long.
  2. #22
    Apr 2004
    5734
    Re: I need help making a digital scanned .igs part turned in to a solid .igs
    Try the Drape command. That will give you a NURBS surface that will be much easier to deal with in Rhino than the meshes you've got. Once you've draped it, intersect it with a plane and Split both of them. Even if it won't join together into a solid, it will let you create curves on the surfaces that you can use to reconstruct your geometry and generate new surfaces using Loft, NetworkSrf or another surfacing command. If you construct those correctly, they should join up to form closed polysurfaces.
    Andrew Werby
    Website
  3. #23
    Sep 2013
    131
    Hi Andrew, I'm no good at this,ha ha. I had a real neck scanned,it took 4 hours to create the mess, and am trying to use the .stl or .igs to make a solid to machine it.
  4. #24
    Jan 2014
    16
Name:	Neck defeatured.jpg
    Iges file in zip
    I may try and copy the back surface from the scan to the defeatured model, the scan is actually very good.
    Scott
  5. #25
    Sep 2013
    131
    That would be perfect, if you can do it, Scott. Thank you very much.
  6. #26
    Nov 2016
    6
    Very nice, I use Catia Solidworks and Mastercam. I tried Geomagic to fix my model, but failed.
    Well, I used Geomagic a few years ago for my hobby (I tried with my son to turn our hobby into a small business but it didn't work out). I could help you with the problems you have, PM me, if you want.
  7. #27
    Jan 2014
    16
    Have a look at the iges.Attachment 343038 The blended surfaces at each end are put on by the guitar maker, usually on a belt sander. So once I have those features on I will upload.
  8. #28
    May 2006
    803
    That is hard core belt sanding torture !
    to blend those.
    Another thing what about a defined stock neck contours. ?
    After the neck plan view, heel and headstock,
    I use these shapes and two thickness dimensions to define full contour as a ruled surface.
    lastly are the blends which are dependent on these shapes.
    The heels and headstock do not change.
    Been doing this too long
  9. #29
    Sep 2013
    131
    You guys are great.
  10. #30
    Sep 2013
    131
    Will Catia do this, using Digitized Shape Editor and Surface reconstruct?.
Page 2 of 2 12
  1. Replies: 34
    Last Post: 07-09-2021, 06:14 PM
  2. Need a part scanned - tips/contacts/costs?
    By SRT Mike in forum 3D Printing / Scanning Software and Hardware
    Last Post: 04-21-2011, 09:06 AM
  3. Help - Scanned outline to part
    By revwarguy in forum Uncategorised CAM Discussion
    Last Post: 05-05-2009, 01:33 AM
  4. I need a large part scanned in Reno, NV
    By Streamlined in forum Employment Opportunity
    Last Post: 03-27-2008, 06:12 AM
