585,991 active members*
5,380 visitors online*
Results 1 to 6 of 6
    Dec 2016
    6
    Mold making for vacuum forming
    We just purchased a vacuum forming machine and we've tried a couple of different mold with it and still cant get a decent part that demolds easily. I machined a couple of molds from MDF but it clogs the vacuum when I place the mold over the vacuum hole. Is there a certain type of MDF, or another material, that is porous enough that the air leaks through it? So far we have only tried 1/8" ABS but we'd like to find some less expensive materials to use as well. I'm curious to know what other materials you are using and what temperatures you use for them. Thanks!
    -David
    Feb 2006
    196
    Re: Mold making for vacuum forming
    David, It may be more an issue of your mold geometry rather than your mold material. We've made vacuum forming molds from wood, foam, tooling board, and aluminum. Sometimes we can get away with just raising the mold plug above the platen .04-.06. Other times we need to drill additional vacuum holes to feed down to the vacuum port.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Mar 2008
    683
    Back when I worked in a vacuum mold shop we would cast the molds from something like this... - Alumilite Regular - Black # Then lots of little holes drilled as required.
    Dec 2016
    6
    Thanks for the replies. What size holes are you drilling in the mold? I've tried doing that but the plastic seems to find every little hole/crevice/irregularity in the mold. We've also tried raising the mold up some to let the air flow around it but the plastic sucks into that crevice too, making demolding very difficult. Are you demolding right away when the plastic is still warm? The most recent mold I made I put a 3 degree draft and still had trouble. What kind of foam have you used?
    Feb 2006
    196
    David, we usually drill vac holes at about .040" diameter and raise the plug off of the platen about that much if necessary. We actually just finished a production aluminum vac tool about 20" x 40" that had over 400 vac holes. They need to be strategically placed. If there are no undercuts on your mold then the part should come off fine. We do some lower volume vacuum forming as well and the parts are still a little warm when we pull them. You also dont want the part to shrink onto the mold.
    Doug Pryor
    Akron, OH
    [email protected]
    Dec 2016
    6
    Are you using anything as a mold release agent? The ABS seems to stick to the MDF.
  1. Making a New Vacuum Forming Machine
    By siansoft in forum Vacuum forming, Thermoforming etc
    Last Post: 11-05-2015, 05:53 AM
  2. Vacuum Forming a Large Body Mold -- Help Please
    By cmisegadis in forum Vacuum forming, Thermoforming etc
    Last Post: 03-23-2014, 02:40 AM
  3. Best way to prep mdf mold for making female mold
    By konalure in forum Moldmaking
    Last Post: 10-29-2009, 02:48 PM
  4. ideas about CNC for making Vacuum forming molds
    By Mike S-H in forum Vacuum forming, Thermoforming etc
    Last Post: 07-22-2009, 01:37 PM
  5. Made a vacuum forming table and mold for portable games console
    By bacteria in forum Vacuum forming, Thermoforming etc
    Last Post: 11-06-2008, 01:56 PM
