585,759 active members*
3,910 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Fagor 8020 Screen and axis problems. screen waving?
    Apr 2015
    Hello, I'm having some issues with a mill I recently acquired. I hadn't seen it run prior to buying it, but hoped for the best.
    The screen is waving. I've seen crt monitors white out, or start to go bad, but I've never seen one do this. It almost seems like a screen saver to prevent burnt in image, however I cant find anything saying that the 8020 would have this function. Between the waves the text is readable and it navigates the menus, but doesn't stop rolling. I adjusted the vertical alignment, doesn't help.
    Here is a video.
    https://www.youtube.com/watch?v=tj9nq7RPUcg
    My other issue is my linear encoder seems to be reading movement constantly, not jumping around but instead a steady climb in whichever direction I last moved the table. I can get it to sit still but inconsistently. It reads travel through a glass scale and a fagor encoder. I cleaned the glass scale and read head, didnt seemed to help. I also tried moving the wires around to see if I could get a change in behavior, but nothing changed.
    Controller is on a tree knee mill with x and y driven, z is still manual.
    Any help is greatly appreciated!
    Mar 2008
    169
    Re: Fagor 8020 Screen and axis problems. screen waving?
    You have near the cnc a transformer or a solenoid
  1. Fagor 40i-TS electronic controller stuck in Boot screen.
    By Huskymatt in forum Fagor Automation
    Last Post: 11-23-2016, 12:35 AM
  2. Fagor Controller screen upside down and back to front.
    By Edo_style85 in forum Fagor Automation
    Last Post: 11-10-2016, 05:53 AM
  3. Fagor Controller Screen Upside down and back to front.
    By Edo_style85 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-13-2016, 11:42 AM
  4. FAGOR 8040 MC - Screen setup
    By caecae_eng in forum Fagor Automation
    Last Post: 10-01-2015, 04:34 PM
  5. Replies: 2
    Last Post: 09-02-2011, 03:44 AM
