I have a 2011 Mini Mill, in the last few weeks I noticed that sometimes the coolant pump (not high pressure) wont turn on when the code indicates it should. This appears to be completely random on when it happens, it never seems to miss the command to turn off, only turning on seems to be an issue. The issue with the pump turning on is affected by g-code or by the control
I feel I am generally pretty good at resolving issues like this however understanding how the motor receives the command is stumping me. What I know so far,
The motor is brushless 220v single phase. The pump plugs in to the side of the mill using a round plug with 3 prongs. The confusing part is, the pump has 220v running to it all the time, as soon as the mill boots up the outlet plug shows 220v. However with 220v being fed to the pump (from this plug) the pump does not kick on until the coolant button is pressed on the control panel or instructed to do so in g-code. There are no other wires going to the pump motor nor does it appear to have a circuit board of any type.
I cannot figure out how the motor gets the signal to turn on when the motor has 220v all the time. Does anyone have an experience with these that can shed some light on how this works as well as if the issue is likely the motor or internal to the mill?
Keith
