585,560 active members*
3,449 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, is it possible to disengage tailstock without stoping the spindle ?
Page 1 of 2 12
Results 1 to 20 of 28
    Jun 2015
    4154
    please, is it M55 possible during M03/04 ? kindly !
    ps : just saw that "kindly" is a tag for this thread
    Jun 2015
    4154
    Re: please, is it M55 possible during M03/04 ?
    so is it possible to retract the tailstock from "work" position without stoping the spindle ?
    and please, is it possible to move the tailstock to "home" / "work" during turret movement among X ?
    so far i succeded moving to "home" during turret movement among Z, while X=X_max ( but this trick is a bit useles during machining ) :
    Code:
       G195 SP=1
       G00 X375-VETFX Z100-VETFZ M55 M64
       G00 Z200
       M62
    Jan 2009
    8
    Re: please, is it possible to disengage tailstock without stoping the spindle ?
    Try using M156 (Tailstock interlock OFF) and M157 (tailstock interlock ON). This should allow you to engage/disengage the tailstock while the spindle is running. Also remember the M847 code (tailstock positive limit).
    You may also be able to program the tail stock home by programming it as the W axis. G00 W100 should rapid the tailstock to positive limit (use a larger number if you run in metric). This could be useful for moving it simultaneously with other functions.
    Sent from my iPad using Tapatalk
    Jun 2015
    4154
    hy, i tried some variants, including M156 / 157, and also other M codes, but it did not work 4 me i forgot, control is osp300, lb3000ex2
    i will share soon the code that i tested; please, do you have an example that works ?
    as u sugested, during those tests i also discovered the M847
    G00 W... does nothing on my lathe i think that if it would work, than i could syncro W with other axis
    however, even so, there may be problems, because "G00 W=home" is not the same as M55; for example if you are with the W @ home position, but there is no M55, than machine will show some errors
    i think that "G00 W=home" + "M55" = "M847"
    also, syncro / CTR including the tailstock should not include G codes for W, but M64 ( M ignore ) + M55/56 + M62, because going syncro on W and other axis may lead to a case when movement for those axis, even if it is started at same moment, is executed with different durations; thus, the cnc will wait until bought axis are in position, and after that next line will be executed
    if M64 ( M ignore ) + M55/56 + M62 is used, than "next line" will be executed when "other axis" will reach the "in position point", even if tailstock is allready there, or is still moving
    normal CRT includes syncro on linear and rotary axis, and rotaries execute the comand much faster than the linear axis, thus control waits for linear axis to perform the comand, and not for the rotary
    going syncro between 2 linear axis, one being the W, means waiting until 2 long duration comands will execute, and this may be tricky to control from G codes if i may, did you took this into consideration ? kindly !
    Apr 2009
    1262
    Have you tried the M167/M166 Tailstock Quill Advance retract interlock release?
    Best regards,
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hello mr Wizard good to see you; here are my trials :
    this simple code works, thus allows syncro z&w, but without rpm
    turret will perform bought Z movements while tailstok is moving
    this program can not run if turret is not at Xmax before
    Code:
       G195 SP=1
       G00 X_max Z100 M55 M64
       G00 Z200
       M62
    added :
    ... W home position
    ... W interlock
    ... spindle rotation
    Code:
       G195 SP=1
       M56
       M157
       *1
       G97 S250 M03
       G00 X_max Z100 M55 M64 *2
       G00 Z200
       M62
    at *1 i input a lot of codes, and run the program for each one; i did not succed in disengaging the tailstock during rpm
    after, i input same codes at *2, but still nothing
    this are the codes that i tried :
    ... M166 Ignoring tailstock spindle advance/retract interlack OFF
    ... M167 Ignoring tailstock spindle advance/retract interlack ON
    ... M24 Chuck barrier OFF,tool interference OFF
    ... M25 Chuck barrier ON, tool interference ON
    ... M184 Chuck internal interlock release OFF
    ... M185 Chuck internal interlock release ON
    ... M128 Tailstock swing retract
    ... M129 Tailstock swing advance
    ... M847 Tailstock retraction end position command
    ... M1153 Tailstock control mode
    ... M1194 Tailstock mode check interlock release
    ps : maybe it works somehow, but i did not find the right combination yet kindly !
    Apr 2009
    1262
    Try:
    M56
    M157
    G97 S250 M03
    M167 M185
    G00 Z200
    Jun 2015
    4154
    hello mr Wizard, i just tried it ... and nothing
    during previous trials, i discovered that :
    ... M847 sends tailstock at Wmax
    ... M185 freezes the cnc; actually, when it meets that code, machine does not continue, also there are no errors
    so, this code :
    Code:
       G195 SP=1
       M56
       M157
       G97 S250 M03
       M167 M185 ( stopped here )
       G00 Z200
       M62
    i don't understand what those " ignore / interlack / free " etc codes do ...
    maybe tailstock would disengage if not the "freeze" behaviour kindly !
    Jun 2015
    4154
    i also tried all codes from that black list at position *3
    Code:
        G195 SP=1
        M56
        M157
      ( *1 )
        G97 S250 M03
        *3
        G00 X_max Z100 M55 M64 ( *2 )
        G00 Z200
        M62
    i started a light discussion also with my dealer, but i think i will postpone it till after holidays
    Jun 2015
    4154
    just find this :
    ... M185 Enables spindle rotation while the chuck is unclamped.
    ... M184 Cancels M185.
    ... M157 Enables spindle rotation with the tailstock spindle at the retraction end during center work.
    ... M156 Cancels M157.
    i wonder why they said "tailstock spindle", and not just "tailstock"
    Jun 2015
    4154
    from the manual : "note however that M185 and M157 are options...." maybe i don't have that M185; how should i check ?
    also M185 may not allow tailstock to leave during rpm, but chuck to open and close without stopping ... something like a hidraulic error
    Apr 2009
    1262
    Quote Originally Posted by deadlykitten View Post
    so, this code :
    Code:
       G195 SP=1
       M56
       M157
       G97 S250 M03
       M167  ( stopped here )
       G00 Z200
       M62
    Try again with M185 removed. IF that doesn't work, put the M167 and the M185 on separate lines and test again.
    Normally these are all standard on sub-spindle machines, but since you have a tailstock machine, you will need to check the spec code for the machine. It can normally be found in the back of your electrical cabinet in the Management Data folder. They should be marked with a 1 (ON) in the list.
    When it stops, what is the machine condition? Any alarm? Is Run or STM light on? Is anything blinking in Block Data?
    Best regards,
    Jun 2015
    4154
    hello mr Wizard
    i tried also only with M167 ... i will repeat it tomorow
    i also thought of 2 codes combinations, but i did not find my patience to try; i hoped it will work only with 1 code, but so far it did not
    i will check tomorow if i have this M codes enabled / available
    ... machine is well, just fine
    Any alarm?
    ... only if someone enters and forgots to input the pin code, than alarm will go on, and my phone will ring ... generally this wakes me up
    is Run or STM light on?
    ... i have no clue ... i will check
    ... i won't fall for that
    just kidding i will check ; thank you
    Jun 2015
    4154
    ... but since you have a tailstock machine, you will need to check the spec code for the machine
    i can't figure it out ... if i search inside the "Ospmngcd.cnc" for "M185" or "185" or "167" there are no results
    also there are no results for "156" and "157", but M156 and M157 works on the machine
    also, searching for "ignore" or "ign" will return nothing
    if i search for "inter"; this is what i found ( nothing relevant ) :
    ... EDIT INTERLOCK -
    ... EDIT INTERLOCK C -
    ... B-AXIS INTERPOL. -
    ... INTERRUPT PROGRAM-
    ... INTERRUPT PROG2 -
    ... RECIPROCAL INTER -
    if i search for "int" ( nothing relevant ) :
    ... C-AXIS 1POINT -
    ... TCPC CUT POINT -
    ... M-INTELLIGENCE -
    ... LDR AXIS INTRLCK -
    ... MAINTE DOOR -
    ... EX INT PROGRAM -
    i think i must play arround all these a bit more thank you !
    Code:
     ID113081
     cspsVer.10.0.1     2015-12-16  14:50:42
    (Zip Format Install)
     OSP Software Management Data Card
                                     -------- cf. Attached Approval List --------
    ===========================[ Machine Data ]===================================
    < Type of OSP >
                                  OSP-P300L
    < Type of Machine >
                                  LB3000IIM
                                  1SC-1000
                                  V12
    < Soft Production No >
                                  #00523
    < Project No >
                                  P172300
    < Software Production Date >
                                  2015-12-16
    ===========================[ Customer Data ]==================================
     kitten, deadlykitt3n :)
    ===========================[ NOTE ]===========================================
    < Note NO.1 >
    < Special Spec >
    < Comment >
    [ Not attached Windows System Disk ]
    ===========================[ DVD Media Version Data ]==========================
    [ Windows System CD Version ]
      01
    [ OSP System CD Version ]
      03
    ===========================[ Soft Version Excepted OSP System CD ]============
    [ Windows System Version ]
      5.0.0.E
    [ One-Touch SpreadSheet Sample Contents CD Version ]
      LEMCS-302A-ENG
    [ Microsoft Office Excel Version ]
      Microsoft Excel 2010 English
    [ Collision AvoidanceSystem Machine Model Data CD Version ]
      MMD-LB3000EXIIM-ADA000-303C
    ============================[ Package Soft composition ]======================
    [ NC INSTALLER ]
         INST106G
    [ REALTIME OS DRIVER ]
         VDRV201C
    [ VPS INSTALLER ]
         VPSI402A
    **START
    [ REALTIME OS ]
         VSYS200L
    ccdrps-pv1.35                    - 1/10 - <W01><O03><        LB3000II><P172300>
    [ NC CONTROL ]
         LNC-383K-01-P300A
    [ NC CONTROL MESSAGE ]
         LNC-383K-01-ENG-P300A
         LNC-383K-01-RON-P300A
    [ PLC SYSTEM ]
         PLCS201E
    [ PLC SYSTEM MESSAGE ]
            [N/A]
    [ NC ALARM HELP ]
         LPA-302A-ENG
         LPA-302A-RON
    [ NC MAMUAL ]
         LPM-100K-ENG
         LPM-100K-RON
    [ P100 TOOL ]
         UTY-003A
    [ PLC CONTROL ]
         LU2-104B
    [ ONE TOUCH IGF ]
         LADVA434B
    [ ONE TOUCH IGF MESSAGE ]
            [N/A]
    [ VERTICAL FUNCTION KEY ]
         SVFKA302A
    [ VERTICAL FUNCTION KEY MESSAGE ]
         LVFKA302A
    [ ONE-TOUCH SPREADSHEET FILE CONTROLER ]
         SEMCA-207A
    [ ONE-TOUCH SPREADSHEET FILE CONTROLER MESSAGE ]
            [N/A]
    [ ONE-TOUCH SPREADSHEET PREINSTALL CONTENTS ]
         LEMCP-302A-ENG
    [ IT PLAZA APPLICATION COMMON ]
         SITP300A
    [ COLLISION AVOIDANCE SYSTEM ]
         LACSA300L
    [ EASY MODELLING ]
         SOECA329D-P0008A
    [ CUSTOM API ]
         LCAPI-003L-Z002A
    ccdrps-pv1.35                    - 2/10 - <W01><O03><        LB3000II><P172300>
    [ SAFETY CONTROL ]
         SFTY003K
    ccdrps-pv1.35                    - 3/10 - <W01><O03><        LB3000II><P172300>
    ============================[ NC Custom Soft composition ]=====================
    [ LPP ]
         C:\OSP-P\P-MANUAL\LPP\ENG\LPP515N-ENG.CNT
         C:\OSP-P\P-MANUAL\LPP\ENG\*
         C:\OSP-P\P-MANUAL\LPP\RON\LPP515N-RON.CNT
         C:\OSP-P\P-MANUAL\LPP\RON\*
    [ HMI ]
         C:\OSP-P\HMI\PDSN401-LU201D.DLL
         C:\OSP-P\HMI\ENG\PDSN401-LU201DEN.DLL
         C:\OSP-P\HMI\RON\PDSN401-LU201DRO.DLL
         C:\OSP-P\HMI-REG\PSRD401-LU201D.REG
         C:\OSP-P\HMI-REG\PSRN401-LU201D.REG
         C:\OSP-P\HMI\PDSD401-LU201D.DLL
         C:\OSP-P\HMI\ENG\PDSD401-LU201DEN.DLL
         C:\OSP-P\HMI\RON\PDSD401-LU201DRO.DLL
         C:\OSP-P\HMI\PDSP401-LU102T.DLL
         C:\OSP-P\HMI\ENG\PDSP401-LU102TEN.DLL
         C:\OSP-P\HMI\RON\PDSP401-LU102TRO.DLL
    [ PBU-DAT ]
         C:\PBU-DAT\LHDBKST-1200A.PBU
         C:\PBU-DAT\LALMHSA-1202A.PBU
         C:\PBU-DAT\LMCNDTA-1202A.PBU
         C:\PBU-DAT\LPRM11A-1208F.PBU
         C:\PBU-DAT\PLCUA21-LMF72A.PBU
         C:\PBU-DAT\PLCUD11-LA001A.PBU
         C:\PBU-DAT\LNCUDA1-00003A.PBU
         C:\PBU-DAT\PLCUF11-LA001A.PBU
         C:\PBU-DAT\LRKUA30-MFA00-D.PBU
         C:\PBU-DAT\LRKUB20-A00-A.PBT
         C:\PBU-DAT\AXID00-P172300A.PBU
    [ CNS-DAT ]
         C:\OSP-P\TOOLS\SAFETY\SLGC03-LU003H.SEO
         C:\OSP-P\CNS-DAT\AXSPLP3-MF03-A1.CNS
         C:\OSP-P\CNS-DAT\PLCUB11-LA001A.CNS
         C:\OSP-P\CNS-DAT\PLCUC11-LUA101L.CNS
         C:\OSP-P\CNS-DAT\LNCSPEC-1200A.DAT
         C:\OSP-P\CNS-DAT\LNCBSPC-1200A.DAT
         C:\OSP-P\CNS-DAT\ENG\PMCA300-L515N-EN.MSG
         C:\OSP-P\CNS-DAT\RON\PMCA300-L515N-RO.MSG
         C:\OSP-P\CNS-DAT\PFCUA21-L001C.CNS
         C:\OSP-P\CNS-DAT\PMIO200-LU100F.CNS
         C:\OSP-P\SharedDLL\OSPLANGINI\OSPLANGID-ENG-101A.INI
         C:\OSP-P\SharedDLL\OSPLANGINI\OSPLANGID-RON-101A.INI
         C:\OSP-P\SharedDLL\OSPLANGINI\OSPLANG-DEFAULT-ENG-100A.INI
         C:\OSP-P\CNS-DAT\PIOCK11-L002D.DAT
         C:\OSP-P\CNS-DAT\ENG\PIOD21-P172300AE.CNS
         C:\OSP-P\CNS-DAT\SIOD21-P172300A.CNS
         C:\OSP-P\CNS-DAT\SLGCA01-LMF013D.CNS
         C:\OSP-P\CNS-DAT\SSMPL2-SA-UA007-A.CNS
         C:\OSP-P\CNS-DAT\SSMPL2-MA-UA001-A.CNS
         C:\OSP-P\CNS-DAT\SSMPL2-XA-MF001-A.CNS
         C:\OSP-P\CNS-DAT\SSMPL2-ZA-MF001-A.CNS
         C:\OSP-P\CNS-DAT\SSMPL2-WA-MF001-A1.CNS
         C:\OSP-P\CNS-DAT\SSMPL2-TA-MF001-A.CNS
         C:\OSP-P\CNS-DAT\AXSPLS3A-SA-N-UA209-A-2.CNS
         C:\OSP-P\CNS-DAT\AXSPLS3B-SA-N-UA209-A-2.CNS
         C:\OSP-P\CNS-DAT\AXSPLS3C-SA-N-UA209-A-2.CNS
         C:\OSP-P\CNS-DAT\AXSPLS3D-SA-N-UA209-A-2.CNS
         C:\OSP-P\CNS-DAT\AXSPLS3-MA-N-UA203-A-1.CNS
         C:\OSP-P\CNS-DAT\AXSPLN3-XA-N-MF202-A-1.CNS
         C:\OSP-P\CNS-DAT\AXSPLN3-ZA-N-MF204-A-1.CNS
         C:\OSP-P\CNS-DAT\AXSPLN3-WA-N-MF202-A-1.CNS
    [ MSB ]
         C:\OSP-P\MSB\LMSA320A.MSB
    [ ETC ]
         C:\OSP-P\LMNT300C.DEF
         C:\OSP-P\OSPMNGCD.CNC
         C:\OSP-P\VOLANTE\OSPLOADER-004A.INI
    ccdrps-pv1.35                    - 4/10 - <W01><O03><        LB3000II><P172300>
    **END
    ccdrps-pv1.35                    - 5/10 - <W01><O03><        LB3000II><P172300>
    ===========================[ NC-SPEC CODE No.1 ]==============================
    1100-0100-4101-0000-14F0-0F18-1300-0043
    0001-BD52-2101-0100-0111-6000-1021-0002
    SLANT-Y AXIS     -  ONE TOUCH IGF ADVo  EXTERNAL MEASURE -  TOOL CENTER CTRL -
    Y AXIS BY CT-Z   -  TAPE DATA IN/OUT o  MEASURE RS232C   -  Hi-Cut Pro       o
    ABSO SCALE YS    -  FD IN/OUT(IBM)   -  CEJ MATIC        -  SUPER-NURBS Hi.  -
    Y-AXIS BARRIER   -  WITHOUT MS-DOS   -  SIZE CATCHER     -  NURBS            -
    Y HORI.BARRIER   -  T-SEPARATE EDIT  -  EX.MEASURE BCD   -  SUPER Hi-NC      -
    B-AXIS 0.001‹   -  DNC-C ETHERNET   -  T-SETTER R/L COM -  SUPER-NURBS Rac. -
    B-AXIS 1‹PITCH  -  P-200 SPEC       o                   -  TOOL-ID          -
    B-AXIS CONTROL   -  FL-net           -                   -  Inverse Time Feed-
    ATC              -  BUFFER 160M      -  TOUCH SETTER     o  ST. REST ZB      -
    1CAM-ATC         -  BUFFER 320M      -  2ND SP MEASURE   -  ST. REST MID     -
    2CAM-ATC         -  BUFFER 640M      -  TOUCH SETTER AUTO-  ST. REST ZC      -
    EXT.ATC HOME POS -  BUFFER 1280M     -  TOUCH SENSOR     -                   -
    VTM MACHINE      -  NO-SSU-RD        -  C ZERO OFFSET    -  ST.R TOW-A.B     -
    NEW MG.PANEL     -  FDD3.5INCH EDIT  -  Y GAUGING        -  ST.R TOW-A.AUTO  -
    PANEL OLD TYPE   -  EDIT INTERLOCK   -  OPTICAL SENSOR   -  ST.R TOW-A.JOG   -
    Y-AXIS TRQUE LIM.-  EDIT INTERLOCK C -  MEASU.DATA PRT.  -  ST. REST TOW-A.  -
    HI-G CONTROL     o  PROGRAM SELECT   -  PITCH ERROR COMP o  CE MARKING       o
    PFC‡U            -  MG TOOL READY    -  IND.PITCH COMP.  -  PITCH ER.COMP.SP.-
    B-AXIS COMP.     -  COMMON VAR. NAME -  ABSO SCALE ZA    -  NC DOOR          -
    X-AXIS COMP.     -  HOME POSITION B  -  ABSO SCALE XA    -  SPEC. SELECT     -
    WK.CORDINATE 10  -  WARMING UP       -  ABSO SCALE ZB    -  R SPEC           -
    WK.CORDINATE 50  -  MACHINE LOCK SP. -  ABSO SCALE XB    -  NOT R SPEC       o
    TOOL OFFSET 500  -  G00 LINEAR FEED  -  ABSO SCALE CA    -  THERMAL COMP. L2 -
    TOOL LIFE WARN.  -  A/B SYNC. MOTION -  WITHOUT COMP.    -  THERMAL COMP. L1 -
    NC TURRET        o  PLANE CONVERSION o  TURRET POS.COMP. o  NC MASTER        -
    OTC TURRET       -  PROFILE GENERAT. o  TOOL OFFSET 64   -  S-LINK NC TEST   -
    CAM TURRET       -  CONTOUR CUTTING. -  TOOL OFFSET 96   -  S-LINK SP TEST   -
    MANY CHIPS TOOL  -  B-AXIS INTERPOL. -  TOOL LIFE MNGMNT -  OH               -
    ABSO SCALE TA    -  SYNCHRO.TAPPING  o  TOOL OFFSET 200  -  NEW OPERAT.PANEL o
    B-AXIS TURRET    -  FLAT TURNING     -  TOOL WEAR COMP.  o  NO SERVO         -
    HEAVY TOOLING    o  HELICAL CUTTING  -  TOOL OFFSET SYS. -  PLC/SFC PROGRAM  -
    DOUBLE TOOLING   -  SLANT CUTTING    -  TOOL OFFSET 800  -  PLC              -
    LT MACHINE       -  HOME POSITION    -  0.0001M CONTROL  -  NC ROBOT         -
    SUB SPINDLE      -  SPINDLE SYNC.TAP -  I/M SWICTH       o  NC LOADER        -
    PARALLEL 2 SPNDL -  TOOL RETRACTION  -  SCRIPT FUNCTION  -  SYSTEM STAT.DISP -
    PICK OFF UNIT    -  SPIN. FLUCTUATE  o  WINDOWS OPERATION-  OH LOGO CHANGE   -
    VERTICAL MACHINE -  NC TORQUE LIMIT. o  CYCLE TIME CAL.  o  C-AXIS COMP. 2   -
    LAW-V MACHINE    -  THREAD OVERRIDE  -  CYCLE TIME REDUC -  F CONVERT        -
    ACC MACHINE      -  GM CODE MCRO     -  CYCLE TIME R.NEW o  LOST MOTION CMP. -
    B-TURRET SUB SP. -  CENTER COMP.     -  NO LOAD DETECT   -  PLR2 LOW SEQUENCE-
    MULTIPLE MACHINE o  LAP4             o  NC WORK COUNTER  o  PROG. TAIL STOCK -
    B-TURRET M-AXIS  -  NOSE-R 2B        o  WORK CNT.SPECIAL -  SIMPLE TOW-ALONG -
    M-AXIS NO C-AX.  -  USER TASK 2      o  NC WORK MONITOR  o  PG. TAIL STOCK B -
    T/M AXIS SW.     -  EXP.AUTO CHAMF   o  CYCLE TIME CHECK o  AUTO TAIL STOCK  -
    L TOOL INDEX     -  THREAD PNT.OFFST -  LOAD MONITOR     o  TAIL STOCK CLUMP -
    C-AX.PT.ERR.CMP. -  THREAD FEED HOLD -  LOAD MONITOR W   o  NC TAIL STOCK    o
    MULTI-MAGAZINE   -  ARC THREAD CUT.  -  MAC MAN COMM.    -  NC TAIL STOCK TRQo
    SYNCHRO. REVERSE -  COMMON VAR. 1000 -  MAC MAN          o  MANY CHIPS 12    -
    2 SADDLE MACHINE -  ONE TOUCH IGF    -  DNC-T1           o  SPINDLE ORIENT.  o
    MIRROR IMAGE     -  IGF              -  DNC-T2           -  MANY CHIPS 4     -
    Z-W OVER LAP     -  IGF CONVERT      -  DNC-T3           -  CB-AX. WO MB-AX. -
    CAM MACHINE      -  IGF DATA TRANS   -  DNC-T4           -  C SYNC. CONTROL  -
    NEW W-DATA       -  ONE-TOUCH S/SHEETo  DNC-P1           -  M-AXIS ORIENT.   o
    SUB MAGAZINE     -  COL.AVOID.SYSTEM o  DNC-P2           -  L MULTIPLE MACHIN-
    H1 TURRET        -  PROGRAMING HELP  o  DNC-P3           -  R MULTIPLE MACHIN-
    FLAT BED         -  HELP             o  DNC-P4           -  HOB CUTTING      -
    SERVO LINK NC    o  STN L.C.D MONO.  -  DNC-A            -  SPINDLE MAX IL.  o
                     -  E100 SPEC.       -  DNC-B            -  SP-HEAD IL.      -
    0 OFFSET DETECT  -  3D. ANIMATION    o  DNC-C1           -  PARTS CA. IL.    -
                     -  ACP EXPANSION    -  DNC-C2           -  1S PARTS CA. IL. -
    SERVO LINK SPNDL o  ANIMATION        o  DNC-C3           -  ZA-W AXIS IL.    -
    SPINDLE ANALOG   -  S10 SPEC.        -  DNC-DT           -  XB-W AXIS IL.    -
    SPINDLE I/O      -  U100/U10 SPEC.   -  SMPL.REMOTE DIAG -  TURRET ZA-W IL.  -
                     -  OAC MESSAGE      -  DNC-RT           -  TAIL-ST.REST IL. -
    ccdrps-pv1.35                    - 6/10 - <W01><O03><        LB3000II><P172300>
    ===========================[ NC-B SPEC CODE No.1 ]============================
    0060-A300-0000-0000-3005-5100-0000-0000
    0000-0300-0000-0000-0000-0500-0000-0000
    COORDINATE CONV. -  ATTACHMENT       -  A-TRT MID. POS.  -  CAM-AXIS ICB     -
    WK.CORDINATE 100 -  ATTACHMENT SWIVEL-  B-TRT MID. POS.  -  CAM LE. LESS     -
    TOOL OFFSET 999  -  MLT MAG. TYPE-C  -  C-TRT MID. POS.  -                   -
    CORDINATE CAL    -  VTR              -                   -                   -
    PROGRAM MESSAGE  -  LONG BORING BAR B-                   -                   -
    3-D CO. CONV.    -  3-D CO. CONV. 2  -                   -                   -
    PROF.GENE.HELI.  -  3-D INDEX        -                   -                   -
    PREMIUM THREAD   -  L TOOL INDEX SP. -                   -                   -
    NC TST HI PRECISE-  MEAS.DATA COMM.SP-  HI-SPEED RESTART -                   -
    NC TST POLS LOW  -  3 AXIS MEASURE   -  L-G IGF LINK     -                   -
    NC TST CHECK LESS-                   -                   -                   -
    TST 1ST-SP ATT.  -                   -                   -                   -
    W AXIS CUTTING   -                   -                   -                   -
    NC TST 1st INCH  -                   -                   -                   -
    NC TST INCH      -                   -                   -                   -
    APC              -  TOUCH SETTER2    -  ABCO SCALE YSB   -                   -
    NC UNLOADER      -  STROKE LIMIT RLS -  ABSO SCALE YSC   -                   -
                     -  RIGID TOUCH SETR -  ABSO SCALE XC    -                   -
                     -  Y-MODE TOUCH SETR-  ABSO SCALE ZC    -                   -
    L TOOL IDX. SEL  -  TL BRAK. DETECT. -                   -                   -
    MLT MAG. TYPE-B  -  AE SENSOR        -                   -                   -
    ATC.EX.HP        -                   -                   -                   -
    POT TOOL TABLE   -  STROKE DIVIDE    -                   -                   -
    MG-AXIS ATC      -  PLC CROSS RAIL   -  B-TRT Y-AXIS     -                   -
    C-AXIS 1POINT    -  NC CROSS RAIL    -                   -                   -
    RT-AXIS ATC      -  HP CROSS RAIL    -  ZA-ZC AXIS IL    -                   -
    TR. ATC TYPE-A   -                   -  3 SADDLE MACHINE -                   -
    TR. ATC TYPE-B   -                   -  C-TRT M-AXIS     -                   -
    TR. ATC TYPE-C   -                   -  C-TRT SUB SPNDLE -                   -
                     -                   -  C-TRT Y-AXIS     -                   -
    CUSTOM-API       -  TOOL DIRECTION   -  SA AXIS TANDEM   -  2M1L ONE SIDE CUT-
    OSP-API          -  TOOL DIR COMP.   -  SB AXIS TANDEM   -                   -
    USER TASK 3      -  TCPC MACHINE CO. -  SPINDLE ACCEL SET-                   -
    THiNC ALARM      -  TCPC CUT POINT   -  SPINDLE ROT. 0.1 -                   -
    M-INTELLIGENCE   -  TCPC SUB SPINDLE -  STEP CUTTING FEED-                   -
    M-SPN. FLUCTUATE -                   -                   -                   -
    L-GUIDANCE       -                   -  TOOL GROOVE PROC.-                   -
    M-GUIDANCE       -  SUPER PROF. GENE.-  SP.COL. DETECTION-                   -
    USE TOOL DISP.   o  AXIS ACTIVE STOP o  CE MARKING STOP  o  EASY OPERAT PANELo
    MACHINING MODE   o  M-AX LIFE COUNT  -  MFU              o  MULT OPERAT PANEL-
    NOSE-R DIR CHG   -                   -                   -  L TOOL MAC INFORMo
    INTERRUPT PROGRAM-                   -                   -  EOP ANM SCALE-UP -
    INTERRUPT PROG2  -  VAR. LOST MOTION o                   -  19 INCH EXTEND   -
    BASE OP. SCREEN  o  SERVO NAVI L     -                   -  ECO SUITE        -
    TOOL MAC INFORM. -  RPD FD SPEED SET o                   -  OSP SUITE        -
    OFFSET BASE FIX  o  TIME CONST SELECT-                   -                   -
    SERVO ADJUST SP  -  WORK WEIGHT SET  o  SELF ST.R 1      -  POWER METER      -
    TOOL LIFE NOT.SP -  Y-AX MANUAL FEED -  SELF ST.R 2      -  TH.COMP.OILCON   -
    WORK ROUGH       -  C-AXIS MANUAL CO.o  SELF ST.R 3      -                   -
    ST.REST BARRIER  -  C-AXIS TORQ. SKIP-  SELF ST.R 1 REL. -                   -
    WORK POSITION 30 -  HOME POSITION C  -  SELF ST.R 2 REL. -                   -
    NO HIGH LOW TH.  o  AT ROTATION COMP -  SELF ST.R 3 REL. -                   -
    TORQUE WATCH     o  LONG BORING BAR  -                   -                   -
    TAILSTOCK SP.LOW -  TOOL BASE        -                   -                   -
    TOOL LIFE NOTICE -  SYNC.CONTROL ZA  -  BELT SLIP CHECK  -                   -
    GOT-HMI          -  SYNC.CONTROL XA  -  M BELT SLIP CHECK-                   -
    MEASU.COMP.CLEAR -                   -                   -                   -
    ALARM MESSAGE    -                   -                   -                   -
    OTHER.SYS.WATCH  -  SDF SEPARATE NC  o  GEN. OL. DETECT  -                   -
    CON BACK SP      -  SDF SEPARATE SP  o  NO LOAD DET. EXT -                   -
    0.1u T/M AXIS SP.-  SDF SEPARATE PLC -  LOAD MONITOR EXT -                   -
    LOST MOTION CMP. -  FEED AXIS RETRACT-                   -  REMAI.TIME DISP. -
    ccdrps-pv1.35                    - 7/10 - <W01><O03><        LB3000II><P172300>
    ===========================[ PLC-SPEC CODE No.1 ]=============================
    0200-0210-0101-0100-0100-0012-0001-0110
    0000-0020-C004-0012-0000-0000-1040-0000
    ST. REST FIX     -  HIGH COOLANT     -  OVERRIDE SPECIAL -  L TOOL INDEX SP  -
    ST. REST MID     -  B-TURRET 1MMTR   -  LOAD MONITOR     o  TL EXST COMF.REV.-
    ST. REST LOW-T   -  A-COOLANT 1MMTR  -  SAFETY TAPE SW   -                   -
    ST. REST REL.    -  COOLANT H/L SP.  -  NC MASTER        -  FL-net           -
    ST. REST OPEN    -  CLNT LEVEL CHECK o  CYCLE TIME RE.NEWo                   -
    ST. REST CLOSE   -  CLNT FLOW CHECK  -  LAW-F L-MACHINE  -                   -
    ST. REST TOW-A   -  COOLANT L/M CHG. -  PNL.POSIT. FRONT -                   -
    ST. REST GR.COMF -  CLNT.THRU.SPNDL. -  T CONST SWITCH   -                   -
    CENTER WORK      o  M-AXIS ORIENT.   o  DNC-B            -  B-AXIS TURRET    -
    TAIL STOCK LIMIT -  FLAT TURNING     -  DNC-C            -  B-AXIS 1‹PITCH  -
    TAIL-STK.IL.RLS. -  B-TURRET M-AXIS  -  ATC TYPE G       -  B-AXIS 0.001‹   -
    PROG. TAIL STOCK -  B-AXIS POS LOMP  -  W-AXIS OVERLAP   -  TURRET TYPE-H1   -
    SIMPLE TOW-ALONG -  ATC TYPE H       -  ST.R AUTO TOW-A B-  TURRET TYPE-H2   -
    TAIL STK.RT.INCH -  CAM AXIS LUB.    -  THREAD OVERRIDE  -  TR.PNDLM.CNTRL.  -
    ST.R AUTO TOW-A. -  M-AXIS OIL MIST  -  IND.CHK1 NO CHECK-  L TOOL INDEX     -
    ST. R. ENABLE SW -  M-SP. OILCOOLER  -  PROG. TAIL STK. B-  L TOOL THD. CLMP -
    CHUCK GRASP COMF o  TOUCH SETTER     o  WARMING UP       -  NO CEIL 2        -
    CHUCK IL. RLS.   -  TOUCH SET. SLIDE -  WORK CNT.SPECIAL -  NO CEIL 3        -
    CHUCK. MISS 1 SP -  TOUCH SET. COVER -  CHIP CNVYR CHECK o  WORK STOCKER     -
    CHUCK. MISS 2 SP -  TOUCH SET. MOTOR -  THRU&MEASURE AIR -  WORK STOCKER2    -
    CHUCK H/L 1 SP.  -  TL BRAK. DETECT. -  DRAIN PUMP       -  VERTICAL SW. LO. -
    CHUCK H/L 2 SP.  -  WORK EJECTOR     -  SP AIR PURGE DET -  T.CLMP OUTPUT HLD-
    INDEX CHK 45 1SP -  WORK EJ.AD CONF  -  AIR PRES.DETECT  -  B-PANEL          o
    INDEX CHK 90 1SP -  WORK EJ.RT CONF  -  SEQUENCER ALARM  -  NC DOOR          -
    2 CHUCK PDL. 1SP o  EXTERNAL MEASURE -  DUAL START       -  NC ROBOT         -
    SMW CHUCK 1 SP.  -  EX. MEASURE BCD  -  DUAL ST.DR. CLS. -  OR5              -
    FR.DRV.CHUCK 1SP -  CEJ MATIC        -  EDIT INTERLOCK   -  HYD ER DET.      -
    CHK GRSP SPC 1SP -  TOUCH SENSOR 2SP -  PROG.STOP SPECIA -  SPEC SELECT      -
    2 CHUCK PDL. 2SP -  TOUCH SENSOR     -  PANEL POSIT. SP  -  NO CE DOOR OPENLSo
    SMW CHUCK 2SP    -  OPTICAL SENSOR   -  PORTABLE PH      -  OSP CHIP CONVERE -
    FR.DRV.CHUCK 2SP -  2SP TOUCH SETTER -  CE MARKING       o  SWING&LIMIT SWIVE-
    CHK GRSP SPC 2SP -  TOUCH SET. COV.LK-  OIL LEVEL DETECT o  OR SEFTY FENCE   -
    HYD. UNIT COOLER -  MECHA-LOCK DOOR1 -  BF/PC BIT SWITCH -  A CLAMP MISS CHK -
    OIL COOLER ALM-A -  MECHA-LOCK DOOR2 o  PARTS CATCHER    -  B CLAMP MISS CHK -
    HYD. OIL COOLER  -  R.DOOR2          -  PARTS CA.DOOR IL -  SWING IL TYPE-A  -
    WITHOUT STE SW   -  AUTO DOOR2       -  PARTS CA.AD/RT SP-  SWING IL TYPE-B  -
    EX BRAKE RELEASE o  DOOR IL. S       o  PARTS CA.SWING   -  DUAL HAND OPE.   -
    SAFETY RELAY     -  DOOR IL. D       -  NC TAIL STOCK    o  FENCE MECHA-LOCK -
    POS UNIT         -  DOOR IL. E       -  CONV.DEVICE I/F  -  HAND OPE. I.L.   -
    CHUCK IL.RLS.SP  -  MECHA-LOCK SP.   -  UNLOADER  I/F    -  LDR AXIS INTRLCK -
    SPNDL OIL AIR LUB-  DR.SPEED SWITCH  -  BAR FEEDER I/F 1 -  NC LOADER        -
    SPNDL ORNT.ELEC. o  AUTO DOOR        -  BAR FEEDER I/F 2 -  NC LOADER TYPE-C -
    SPNDL ORNT. PIN  -  DOOR CONTROL     -  B.FEEDER CHK.IL. -  2M1L             -
    SPNDL ORNT. BRK. -  R.DOOR ONE BODY  -  BAR FEEDER I/F 3 -  3M1L             -
    1SP. LOWEST SP.  -  R.DOOR SIDE OPEN -  BAR FEEDER I/F 4 -  GANTRY LOADER    -
    2SP. LOWEST SP.  -  ROOF DOOR        -  BAR FEEDER I/F 5 -  RECIPROCAL INTER -
    1SP. OIL COOLER  -  PL DOOR I.L.E-D  -  THRU. AIRBLOW IL.-  2CARRIERS LDR    -
    2SP. OIL COOLER  -  PL DOOR I.L.E-C  -  CUT OFF DETECT   -  3 AXIS LOADER    -
    0.0001M CONTROL  -  ATC TYPE A       -  RBT/LDR I/F B    -  TURNOVER DEVICE  -
    FLAT BED         -  ATC TYPE B       -  RBT/LDR I/F C    -  TRNOVR RTRCT SP. -
    W-AXIS CONTROL   -  ATC TYPE C       -  RBT/LDR I/F D    -  TURNOVER L->R    -
    HYD LESS         -  ATC TYPE D       -  OGL LOADER I/F   -  DIREC SWITCHABLE -
    W-AXIS CLAMP     -  MG. DOOR 2       -  PROGRAM SELECT A -  MULTI-MAGAZINE   -
    HOB CUTTING      -  MG.DOOR MECHA-LK -  PROGRAM SELECT B -  M.LOCK SP CVR.   -
    B-TURRET SUB SP. -  MG TOOL MAN CHG  -  PROGRAM SELECT C -  LVT SAFETY FENCE -
    B-AXIS INTERPOL. -  TOOL ID          -  FIX POT ATC      -  MEASURE OVER M/C -
    2 SADDLE MACHINE -  NC TURRET        o  LFS10            -  FINGER CHUCK 4-1 -
    MULTIPLE MACHINE o  TURRET LIMIT A   -  LVT              -  FINGER CHUCK 4-2 -
    OPPOSED TURRET   -  CAM TURRET       -  LAW-V            -  FINGER CHUCK 2-1 -
    SUB SPINDLE      -  NC TR WITH BRAKE -  2SP-H            -  FINGER CHUCK 2-2 -
    OPPOSED 2 SPNDL  -  TURRET LIMIT B   -  ACC MACHINE      -  COLLET GRSP COMF -
    SLANT-Y AXIS     -  1MMT CLUTCH COMF.-  ATC TYPE-E       -  SIDE COVER I.L.  -
    PARALLEL 2 SPNDL -  1 MOTOR MULTI TR -  ATC TYPE-F       -  M.LOCK SIDE CVR. -
    B-AXIS TURRET    -  1MMT BRAKE CR    -  SUB MAGAZINE     -  SUB PANEL        -
    ccdrps-pv1.35                    - 8/10 - <W01><O03><        LB3000II><P172300>
    ===========================[ PLC-SPEC CODE No.2 ]===========================
    0100-0200-0300-0000-0000-0000-0000-0000
    0000-0001-0010-0000-0000-0000-0088-0000
    HP COOLANT UNIT  -  1SP C BRAKE KEEP -  MAN JOG FEED     -                   -
    HP COOLANT UNIT2 -  2SP C BRAKE KEEP -  SP COM. UNIT 0.1 -                   -
    HP COOLANT UNIT3 -  FD.CHUCK 1 GRSP  -  CHIP NIPPING AVO.-                   -
    RV. FLUSH CLNT   -  FD.CHUCK GRSP.CK -  CAT TOOL DIR.    -                   -
    BL. SADDLE CLNT  -  C UNCLAMP CONF.  -  TABLE ROUND CONV.-                   -
    ANOTHER TANK     -  1SP A.CHUCK RSS  -  MG CLAMP         -                   -
    RV. FLUSH CLNT2  -  2SP A.CHUCK RSS  -  SETUP MODE       -                   -
    SP TAIL WORK HLD -  NC ST. R. CLAMP  -  GEN. OL. DETECT  -                   -
    SAFETY SW RST    -  OPTICAL SENSOR B -  RIGID TURRET     -  SIDE SHUTTER     -
    DOOR DIVISION    -  TOUCH SET.SLD B  -  A-TURRET PENDULUM-  TCH STTR POS RV  -
    FLAT DOOR IL     -  TOUCH SET.CROS-L -  B-TURRET PENDULUM-  1SP CHK GRASP C  -
    FLAT 1 DOOR      -  TOUCH SET.CROS-R1-  A-TURRET PND. SW.-  2SP CHK GRASP C  -
    FLAT DOOR IL SP  -  TOUCH SET.CROS-R2-  B-TURRET PND. SW.-  W-AXIS CUTTING   -
    FLAT DOOR MLK    -  TOUCH SET.SLID R -  DOOR IL. SW CHECK-  TOUCH SET.TRN.SLD-
    R.DR.GUIDE SLIDE -  TR.&MEASURE AIR  -  OSP CNVYR PNL.SP -  DOOR I.L.E-C SP  -
    MAINTE DOOR      -  T SETTER MOTOR B -  SPNDL LUBE DRAIN -  SP. LATHE TOOL   -
    NC STEADY REST   -  SCHUNK CHUCK 1 SP-  ACC AREA SENSOR  -  MCTYPE VTR-A     -
    ST REST AIR CLAMP-  SCHUNK CHUCK 2 SP-  SP VIB. SENSOR   -  ANGLE HEAD       -
    SELF ST.R 1      -  CHUCK H/L B 1SP. -  S-ST CHK. PDL/PB -  L-NAVI GUIDANCE  -
    SELF ST.R 2      -  P-TS UNCLAMP IL  -  APC SPNDL CLAMP  -  EASY OPERAT PANELo
    SELF ST.R 3      -  HP COOLANT UNIT5 -  PH TYPE-B        o  ANG COOLANT      -
    SELF ST.R 1 REL. -  HP COOLANT UNIT6 -  C CONNECT SP     -  ANG AIRBLOW      -
    SELF ST.R 2 REL. -  VTR CHUCK CTRL   -  PH TYPE-C        -  SHOWER SW        -
    SELF ST.R 3 REL. -  2APC SETUP CLAMP -  THINC ALARM      -  MF UNIT          o
    NC TAIL WORK HLD o  HAND PUSH. AIR   -  2PALLET APC      -  ATC TYPE-P       -
    NC TAIL NO CHG   o  STOCKER INV.CTRL -  STACKER CRANE I/F-  ATC NO MOD RST   -
    NC TAIL NO PEDAL -  STCK.AREA SENSOR -  C AXIS GROUP SW. -  DOOR WINDOW      -
    HYD QL NC TAIL   -  3AX LDR SWING IL -  PALLET CLAMP B   -  DRUM FILTER      -
    NC TAIL PRECISE  -  CHUCK H/L B 2SP. -  2PALLET APC I/F C-  PH ENABLE SW     -
    NC TAIL POLS LOW -  1SP C GAIN CUT   -  6PALLET APC I/F C-  ATC SIDE TH.TOOL -
    TAIL SLEEVE I.L  -  2SP C GAIN CUT   -  APC DOOR         -  ST.REST MAN GRIP -
    TAIL SLEEVE 1SP  -  NC UNLOADER      -  PALLET CLAMP C   -  3 SADDLE MACHINE -
    CHUCK GRASP CO.B1-  SUB PNL.B ST.CHG -  NEW CEMK         o  AIR NOZZLE SW    -
    CHUCK GRASP CO.B2-  CENT.PARTITION   -  M-NAVI GUIDANCE  -  M-SP AIRBLOW SW  -
    ST. REST ZC      -  SP PEAK POW. CUT -  SUB PNL.B BIT SW -  CHIP CON SW      -
    NC TAIL INCHING  -  CE CHUCK NO CONF -  ATC OIL PRES.DET -  OILMIST SW       -
    INDEX CHK 45/90SW-  ATC TYPE-Q       -  OIL LEVEL DET.2  -  OILHOLE SW       -
    2SP CHK DS SENSOR-  MULTI-MAG. B     -  VERT. MLT. PANEL -  OILHOLE HIGH SW  -
    CHUCK GRASP CO.D1-  APC FRONT DOOR2  -  OPERATION DOOR   -  COOLANT CLOG     -
    CHUCK GRASP CO.D2-  CHUCK/JIG CHANGE -  C CLAMP CONF.    -  COOLANT LV CHECK -
    SP. LOW. FIX. SP.-  A TURRET MID.    -  PWR SUP R/L COM  -  M-SP COOLING     -
    C AXS BR. TRQ LMTo  B TURRET MID.    -  EX CUT FEED OVR  -  THR SP COOLANT   -
    SKIVING CUT      -  C TURRET MID.    -  EX INT PROGRAM   -  X-AXIS OILMIST   -
    TURN.TOOL GROOVE -  2APC I/F B       -  SUB PANEL B      -  OIL SKIMMER      -
    1SP WIND-CHG SP  -  L TOOL IDX. SEL  -  EX NC FEED HOLD  -  COOLANT COOLING  -
    2SP WIND-CHG SP  -  B 2MMTR TYPE B   -  INSIDE M/C CNVYR -  COOLANT SW       -
    SP BRAKE PS      -  C MODE C BRAKE   -  LIST UP MOSNIC A -  WORK WASH SW     -
    MAN MODE C BRAKE -  TAIL STOCK CLAMP -  LIST UP MOSNIC B -  CHIP FLUSH SW    -
    MANY CHIPS 12    -  M-SP LUBE CHECK  -  HP COOLANT UNIT4 -  AAC              -
    MANY CHIPS 8     -  M-SP OIL AIR     -  AXIS RETRACT     -  M-SP CL/UC MCODE -
    ATC POS INDEX RE -  MA-SP. LOWEST    -  CROSS RAIL AUTO 7-  AT MCODE         -
    B-AXIS 5deg PITCH-  M-SP 4P INDEX    -  CROSS RAIL AUTO 8-  AT-C INDEX 5DEG  -
    MANY CHIPS 4     -  TOOL M-SP.MAX    -  CROSS RAIL AUTO 9-  MAN AT TOOL CHG  -
    TL EXIST COMF.   -  C-TURRET M-AXIS  -  CROSS RAIL AUTO10-  AAC TYPE B       -
    TURNING IL       -  CHIP BITING AV.  -  DOOR IL S SP     -  DOOR IL S SP2    -
    2MOTOR TR TYPE B -  Machin. Navi M-i -  PENDANT IL       -  CONVEYER HOLD DR -
    2MOTOR MULTI TR  o  LINEAR GUIDE CVR.-  FIRE ALARM CHK   -  ATC TYPE M       -
    2MOTOR TR B      -  ATC CYCL TIME RE -  MIST COLLECTOR   -  ATC SHUTTER      -
    TR INDEX COND W  -  ATC TYPE I       -  0.1UM PH CHG     -  MATRIX TIM.RE.A  -
    2SP-H TR.CLMP-R  -  EX ATC HP        -  CROSS RAIL AUTO  -  MATRIX TIM.RE.B  -
    2SP-H TR.CLMP-L  -  ATC TYPE J       -  CROSS RAIL AT-C  -  ATC COV.TOOL     -
    B TURRET Y       -  ATC TYPE K       -  SP ER DET. SHARE -  ATC LATHE TOOL   -
    C TURRET Y       -  TOOL RET MT CM   -  ABSO SCALE FILT. -  ATC TYPE N       -
    2 MOTOR TR C     -  ATC TYPE L       -  1SP INDEX CHK SP -  ATC SENS. TOOL   -
    ccdrps-pv1.35                    - 9/10 - <W01><O03><        LB3000II><P172300>
    ===========================[ PLC-SPEC CODE No.3 ]===========================
    0000-0000-0000-0000-0000-0000-0000-0000
    ECO SUITE        -                   -                   -                   -
    ccdrps-pv1.35                    - 10/10 - <W01><O03><        LB3000II><P172300>
    Apr 2009
    1262
    It appears that you are missing both the chuck interlock release and the tailstock interlock release from your spec table. You'd have to order the options from okuma.
    Jun 2015
    4154
    hello mr Wizard, and thank you !
    (your) experience is required to know the association between an M code and the description from the mngmnt data card
    i put all those into an *.xls file, and i have highlighted with green the functions that are active on the lathe, and with orange i highlighted the ones that i don't know what they do, not that i am 100% sure about the rest ... and my god, there are so many oranges i printed that into attached *.pdf
    i am afraid that there might be functions / options that i don't know that exist; this time i though asking about M55 during rpm, and so i found out about these functions, so thank you again, but maybe i will keep doing some other things in my way, without knowing a better way to do it, because i don't know what / how to ask
    in my opinion, the functions listed in the mngmnt data card are not only for my lathe, thus they are not specific to a single machine, but they are specific to the control, that may be installed on different cnc types ...
    however, i don't understand most of the functions, and if i could i would buy you a stake and a beer, so to have a small talk but ...
    Attached Thumbnails Attached Thumbnails Ospmngcd decembrie 2016.pdf
    Jun 2015
    4154
    if i could, i would buy you a stake and a beer, so to have a small talk but ...
    i will raise my offer : whatever menu you wish at a penthouse in a tropical place with lots of bunnies and some plastic stuffs
    Jun 2015
    4154
    hello kurmay :) yup, you with the EEEE avatar and weird signatures : welcome to Antarctica >:D<
    psst : carefull, we are not alone here :)
    i had a dream a few days ago about you repling in this thread :
    http://www.cnczone.com/forums/okuma/...-software.html
    i was seing text written on the monitor, and i knew that you were tiping; so i only dreamed the monitor, not you :) also, i dreamed only the screen, not the entire monitor, so i don't know if it was flat, or crt, or Hyunday, whatever :)
    i can tell you for sure that it was colored :)
    so, i dreamed that you were adding IF codes inside a *.cnc file, and i was wondering why whould you do that, because that file is never executed by the control; is weird how the conscious side of our brain interprets our dreams :) also text was alligned on my stile, thus 4 spaces indentation, but addreses were not the N* type
    so far it was black text on white ... after, it became white / yellow text on red background, and you were tring to move whatever text to the bottom of the file; something like ctrl+x / ctrl+v, but you did not used those shortcuts; instead you selected the text, and dragged it by mouse ... the text selection was floating, and all text arround it was wrapping, like when you drag an image inside a *.doc file, when the image has the "square" or "tight" atribute, only that it was much cooler; also at this point it was not you anymore, thus it was only the screen
    after, the text got rewritten / refreshed, not fast, also not slow, and some spaces were created inside of it; it was like a printer that writted all that char by char. After all text was written, in those spaces appeared images. After all images apperead, screen moved back to 1st image and stared editing it; changes done inside the image were slow, at same speed how the text was "printed" before, and also these changes were done similiar to how a printer works, from up to bottom
    something like sonny's drawing, from "i am robot", but much cooler; here :
    https://www.youtube.com/watch?v=Bs60aWyLrnI
    i think i dreamed a futuristic text editor, that i onestly doubt to be on the market soon, because it was extremely fast and simple, somehow neuronal conected
    well, also, i think i must take a break; i am checking cnc.zone pretty often, but dream about it ? pfff
    ps : sorry for saying "weird signatures", but think of those like a technical drawing : is not you that must understand it, but everybody that is looking at it :)
    Jun 2015
    4154
    somebody just asked me if i think that it would be possible to control a text editor like that, with my brain, and i replied no, because the one that i dreamed was a bit slower, while a neuro-controled one would be almost instantaneous ... and i got served : not if you are depressive ! hihihi ( thus a slower head )
    Jun 2015
    4154
    hello :) this code clamps & unclamps the tailstock while rpm <> 0
    thank you again mr Wizard >:D<
    ... i have shown my dealer that " taill-stk.il.rls " is not checked
    ... i also sent him attached image
    if it wasn't your help, i could not show my dealer exact infos, thus proving that what i wish for, actually exists :) it took me almost 1.5 years to implement it / duhh
    i owe you one more ! any wishes ?
    Code:
        G50 S2000
        M157 M167
        G00 X500 Z0      ( turret up )
        M55
        G97 S250 M03 M42 ( M08 )
        M56              (   clamping @ low / moderate rpm )
        S2000
        M55              ( unclamping @ high           rpm )
        M02
    Quote Originally Posted by OkumaWiz View Post
    Try:
    M56
    M157
    G97 S250 M03
    M167 M185
    G00 Z200
    i also tried to " rapid up + M55 " in same block, but it does not work
    perhaps M55 requires that the turret is at X+ before executing the current block / kindly :)
Page 1 of 2 12
