586,005 active members*
5,022 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Missing system folder
Results 1 to 12 of 12
    Apr 2011
    68
    Have v25 , latest update , has been working fine, now I am having trouble with simulation - cnc edit . Win 8.1 , I noticed that the system folder is missing from the tree , tried to repair through the repair option in ad remove files , still no sys folder. Hey Al , you out there?
    Ed
    Dec 2011
    361
    Re: Missing system folder
    Ed,
    Could you please specify the specific issue you are having. The simulation is internal to BobCAD-CAM as of V25, so any issues with simulation will be separate from that particular item. As far as the CNC Editor, please click the link below to install the editor.
    Link:
    https://drive.google.com/open?id=0B0...m44ZzR5Uk5jMVU
    Apr 2011
    68
    Sean , the simulation screen comes up with all the tool bars , on the screen and I have to remove the ons I don't want . It never did that before , also when working with a profile , it will not accept and show a error , and these are paths I have used before with no problems. I have reinstalled v25 several times ( latest update ) , no better , when I look at the file tree , I see that there is no system file or folder on it . Should I remove and do a clean install , I have run a full scan , and no threats have come up. I have just purchased v29 Mill , but I need v25 to do my 3d moldings.
    Ed
    Dec 2011
    361
    Ed,
    Download this utility and choose the simulation option. Reset the simulation UI with the simulation closed. See if it resolves the issue.
    Link:
    https://drive.google.com/file/d/0B4f...ew?usp=sharing
    Apr 2011
    68
    It says file does not exist
    Dec 2011
    361
    Ed,
    Weird, seemed to have lost the link for whatever reason. Give this one a try.
    Link:
    Apr 2011
    68
    The cnc editor works now , during simulation I get a unexpected error , then shuts down
    Dec 2011
    361
    Ed,
    What sort of graphics card is that system running on? Is it a dedicated or integrated card?
    Jun 2005
    656
    Check your tool and toolholder definitions too in case they got corrupted. The simulation will crash at start (sometimes with an error message, sometimes not IME) if it doesn't like the tool & toolholder geometry.
    Apr 2011
    68
    I see in my tool library , the tool # are all the same
    Apr 2011
    68
    I see in the tool library all the tool # are the same
    Dec 2011
    361
    Ed,
    Are you still having issues with the simulation crashing?
  1. does camworks have a backup folder
    By bobcad guy in forum CamWorks
    Last Post: 08-05-2013, 12:45 PM
  2. reports folder not migrating
    By coykiesaol in forum Mastercam
    Last Post: 12-07-2010, 07:30 AM
  3. Folder Shuffling
    By WingNutz in forum Mastercam
    Last Post: 12-14-2007, 03:11 PM
  4. Plugin Folder in Mach
    By bill south in forum Mach Software (ArtSoft software)
    Last Post: 09-09-2006, 02:44 PM
