584,829 active members*
5,005 visitors online*
IndustryArena Forum > MetalWorking Machines > Smithy > Fusion 360 Post Processor
Results 1 to 7 of 7
    Aug 2007
    701
    Anyone play with the Automate808d.cps post processor?
    On the Lathe simulator I am getting errors when it posts this line: "LIMS=S3000"
    Apparently the syntax should be "LIMS=3000"
    Also Sean is getting errors with G53. The sim doesn't error with that.
    I am going to play with the post processor to fix the LIMS issue.
    Aug 2007
    701
    Re: Fusion 360 Post Processor
    OK easy fix on the LIMS issue - I just edited the 2 instances of this:
    writeBlock("LIMS=" + sOutput.format(properties.maximumSpindleSpeed))
    and changed to this:
    writeBlock("LIMS=" + properties.maximumSpindleSpeed)
    Now the code outputs:
    LIMS=xxxx instead of LIMS=Sxxxx
    Aug 2007
    701
    I have been playing around with the Post for Fusion 360 and have it working OK.
    Here it is for folks to try out. Be careful as not everything is tested. I mostly was working on getting the drill cycle to work properly as well as the C axis.
    If anything doesn't work or errors out let me know.
    The funny part is if I rename the post - it fails. I can't figure out that one.
    A360
    Dec 2010
    141
    I was struggle with a "no feed rate enable error" last night and finally got something going around 1am this morning. It was kicking my as on the drilling and tapping cycle but I finally got something going and was able to cut the first part. I'll try your post later to see how it does. Thanks
    Aug 2007
    701
    Sin - were u able to get a decent drilling cycle w a G94? My experience was that it would ignore the feedrate and rapid into the part so I changed the post to use G95.
    Also if you issue a G291 it changes to iso mode then you can use standard fanuc code.
    Dec 2010
    141
    I put a G17 right before my feedrate and it worked fine. The post processor needs some help, I'll keep working at it.
    Aug 2007
    701
    I keep updating the one in the link above. Seems to post decent code for me so far.
  1. Working fusion 360 post processor
    By keithmcelhinney in forum Novakon
    Last Post: 04-13-2016, 05:35 AM
  2. fusion 360 post processor
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 03-20-2016, 08:20 PM
  3. SlantPRO post processor for Fusion 360.
    By adamvs in forum Tormach Slant Lathe
    Last Post: 02-26-2016, 05:43 PM
  4. Post processor for Fusion 640M
    By naytep in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2007, 01:30 PM
