585,604 active members*
3,291 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Redsail Laser > problem with redsail cm1690 wont operate at full speed
    Jan 2012
    21
    Question problem with redsail cm1690 wont operate at full speed
    This is a friends laser cutter and I am trying to help him out with the problem he is having. He has tried dealing with the company he bought the machine from but they are giving him the runaround till the warranty is up. But anyway the machine trys to home but when about done there is a buzzing noise and axis jumps. The he jogs/moves the laser over the work and will only work good at slower speed. at higher speed it jumps and skips.
    Like I said I am trying to help a friend out.
    Aug 2016
    75
    Re: problem with redsail cm1690 wont operate at full speed
    Is his proximity sensor(s) lighting up? What about the axis LEDs lights on or off or colors on the controller? What controller? He need to post himself with a very, very detailed post about machine specs, exactly what is happening when and how, an probably post video. Then people will be more inspired to help.
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Jan 2012
    21
    Ok. I will tell my friend to post but he is having problems with the company he bought the new machine from(not returning emails). I repair cnc machines and told him I will try to help him resolve these problems.
    Jan 2012
    21
    When I suggested to my friend about posting on here. He will try if he can not up on the posting on forums thing. So I am still going to help him. I will get more info and try to upload a video on here. All help is appreciated. Thanks in advanced.
  1. Redsail CM1690 - U-Axis question
    By Nickk6 in forum Redsail Laser
    Last Post: 07-30-2017, 04:20 AM
  2. HELP need full speed!!!
    By flash319 in forum LinuxCNC (formerly EMC2)
    Last Post: 08-01-2012, 11:23 AM
  3. Motor Wont come up to speed
    By HellPhish in forum Benchtop Machines
    Last Post: 06-20-2010, 03:52 AM
  4. G-Code --- full speed
    By BeerFizz in forum Mach Mill
    Last Post: 12-09-2007, 03:06 AM
  5. OK goin in... full speed!
    By boosted in forum DIY CNC Router Table Machines
    Last Post: 01-21-2007, 10:41 PM
