585,982 active members*
4,722 visitors online*
Results 1 to 10 of 10
    Jul 2011
    28
    MPC6515 freezes on 1st message
    Hello
    Urgent
    New problem on my machine.
    I turn the key to start the cutting machine but the software stops on the 1st message on the PAD03 display :'System starting. Please Wait. V4.0.3'
    It is therefore impossible to use the machine since no key on the board works. This happens several times.
    To get out of this situation I need to shut down and restart the machine several times. And each time it takes several minutes to see if the machine will start or not. It's very annoying ... especially since I do not know where it comes from. Besides I'm afraid the machine will drop me at the wrong time and I can not guess when this will happen.
    Note that I have already disassembled the 6515 card to clean the connectors with very fine abrasive paper and to suck the dust that settled on it.
    I did the same with the card on the digital display interface PAD03.
    Please can you help me solve this problem or at least know the origin?
    What should I expect?
    Thank you in advance.
    Chinese Laser : Jinan XYZ-TECH CNC Equipment Co,.LTD, Machine : XJ6090, RECI 100 W, MPC6515, Control Panel PAD03, HW 4.0.0.1, FW 4.1.2.3, DLL 4.1.2.2. LaserCut 5.3.
    Nov 2010
    787
    Re: MPC6515 freezes on 1st message
    Poor connection between MPC and PAD03
    CNC lasers, constructions, service
    Jul 2011
    28
    Thank you for the reply.
    I will test this cable with the multimeter on Monday.
    I will come back with the result.
    B.R.
    Nov 2010
    787
    I would check connectors first. Mostly on PAD03.
    Nov 2010
    787
    By the way.
    For 15 years we are selling chinese laser machines. In 2011 we bought one XYZ machine for testing as we do sometimes.
    That was such a scrap that we had to split her for parts.
    Jul 2011
    28
    HI
    I come back to give news but this time the machine has been blocked DEFINITIVELY at the level of the message " System starting. Please Wait. V4.0.3' ". It no longer advances beyond this massage.
    I checked the connection between MPC and PAD03 as recommended by Cinematic2 but the test with the multimeter is good For the 4 wires coming out of the PAD03.
    I re-cleaned the 2 cards a second time but without result.
    Please where does the problem come from?
    What needs to replace?
    Jul 2016
    Hola tengo el mismo problema tal vez lo solucionaste ....
    Jul 2011
    28
    Hi
    Cleaning the connectors all over the MPC6515 has reactivated it especially the connectors connecting the small card to the large card of the MPC6515.
    The origin of the problem : the relatively high climate humidity on a coastal city
    What did I do ? Cleaning with very fine abrasive paper. Moisture must be chased all over the map.
    Caution : Do not damage or bend a pin or circuit board.
    Results : problems remain but the MPC6515 re-runs now and it is already pretty good.
    BR.
    Jul 2011
    28
    MPC6515 replaced with MPC6525A. No more issues. Except the end-of-job ringtone that sometimes does not work!
    Where does this long beep come from? Why sometimes does it not work ?
    Quote Originally Posted by medmouncef View Post
    Hi
    BR.
    hi iam got same error and i know nothing about the parts could you please tell what are the connectors to be cleaned
    thank you
  1. Replies: 17
    Last Post: 08-29-2012, 05:06 PM
  2. Die Blocks
    By gabedrummin in forum RFQ (Request for Quote)
    Last Post: 08-22-2012, 03:56 AM
  3. BPS (Blocks Per Sec.)
    By steve cline in forum Mastercam
    Last Post: 10-24-2011, 05:06 PM
  4. BPS (Blocks Per Sec.)
    By steve cline in forum Haas Mills
    Last Post: 10-19-2011, 05:10 PM
  5. 1-2-3 blocks!?
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 05-07-2009, 07:25 PM
