Dear All,
I recently purchased 2.2KW VFD with Aircooled spindle from China. I also Purchased USB to RS485 connector so that i able to use Mach3 plugin created by
Mach3 plugin for Huanyang VFD | Le royaume d'éole
I was unable to run the Mach3 due to high noise problem created by cheap VFD. I resolved the issues by adding Ferrite Bead on UC100 USB cable as well as RS485 USB cable to VFD and i am having no issues running the system without any interruption or UC100 sync error.
Just for info.. You can salvage Ferrite beads from any cable around you and installed at both ends of cables (Total 4 will be required)
