585,922 active members*
3,413 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Wood cutting with water jet - how much pressure needed?
    Dec 2016
    I would like to cut wood with a thickness of about 5 cm. Does anyone know how much pressure I need approximately? How can I find out which diameter I need for the jet ?
    Thank you for helping!
    Best regards
    Jul 2010
    46
    Re: Wood cutting with water jet - how much pressure needed?
    What sort of cut quality? With or without abrasive? What kind of wood?
    Not enough information to give a useful answer.
    Mar 2015
    178
    I don't think theres any hard and fast rule but certainly more pressure will let you cut faster at a given cut quality. A .014 orifice/.040 mixing tube is a fairly common combo.
    Dec 2016
    thanks for the answers! The wood is soft (I have a lot of palm trees and therefore every year a lot of fronds which I would like to cut in smaller pieces). I don't want to use abrasive. The cut quality doesn't have to be good.
    Thank you!
    Jul 2010
    46
    If you have a lot, I would do some testing. Generally speaking, a larger orifice should let you cut a little faster, as should more pressure.
    If you're trying to use less pressure, I would start with whatever the default orifice size is normally, and work up from 20k based on how the cut test looks.
  1. water pressure valve
    By DanOSB in forum DIY CNC Router Table Machines
    Last Post: 06-27-2010, 08:03 PM
  2. Water Jet cutting Specs needed......
    By PoppaBear10 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-11-2009, 05:13 PM
  3. Water Pressure to Cut 1/8" plywood?
    By J Solinger in forum Waterjet General Topics
    Last Post: 06-06-2005, 02:54 AM
