585,762 active members*
4,174 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > CNCRP Pro4896 with HY 220 VFD and Water cooled spindle - Estop issue fixed
    Aug 2016
    4
    So I finished my build, CNCRP Pro4896, Gecko G540, UC100, 2.2kW water cooled spindle, and CNCRP proximity sensors. I could do an air cut no problem, but with the spindle on it would e-stop after 5-10 mins. I was pulling my hair out thinking it had to be noise. I have went through every post I could find. Rewired my controller 2 times. Checked all my shielded cables over and over again. Checked all my earth grounds, and changed out the e-stop. I installed a EMI filter before the VFD and it worked for about 6 jobs after that; then the next day it started all over again. So back to the drawing board. I started building a new config, and then started doing the VFD plugin. I realized what was happening. I had the e-stop power in the VFD plugin set for 8.5a, but on the VFD I had 9a, so every time it went over 8.5a it was e-stopping. I fixed the amps setting to match in the plugin config and VFD and left e-stop and pulleys unchecked this time. I checked and it still shuts the spindle down when the e-stop is pressed or a limit switch is hit. I have run multiple jobs and no unexpected e-stop so far. I just thought I would put this out there so if someone makes the same boneheaded mistake.
    Good Luck
    Nov 2016
    39
    Re: CNCRP Pro4896 with HY 220 VFD and Water cooled spindle - Estop issue fixed
    Quote Originally Posted by Hsayre2016 View Post
    Good Luck
    Thank you for the information
    I plan on using similar hardware in my next build.
    Served by a Droid
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  3. Accuracy Issues with CNCRP PRO4896-Please Help
    By talonosi in forum Avid CNC
    Last Post: 08-29-2015, 03:00 PM
  4. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  5. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
