584,841 active members*
4,329 visitors online*
    Dec 2016
    HAAS TL1 locked paramaters
    Hi, I regularly use a 2006 HAAS TL1 lathe and have tried to add a floppy disk drive (actually a usb emulator). I have a code for this but when I go to the parameter to enable floppy drive rather than a 1 or 0 it has Ot. When highlighted it tells me the function is locked. Does anyone know how I can access it to enter the code?
    Jan 2017
    25
    Re: HAAS TL1 locked paramaters
    Setting 7 (param lock) and go to your bit and type in the dealer code and enter
  1. Replies: 3
    Last Post: 12-07-2016, 06:17 PM
  2. Haas door hold override(setting 51) locked out
    By quadtard in forum Haas Mills
    Last Post: 08-25-2015, 08:22 PM
  3. Haas GR510 tool change locked
    By PD-CNC-GUY in forum Haas Mills
    Last Post: 05-03-2014, 05:11 AM
  4. Haas 1998 VF2 Spindle Locked
    By Rayginn in forum Haas Mills
    Last Post: 05-09-2011, 11:34 AM
  5. looking for paramaters
    By slrpfi in forum Want To Buy...Need help!
    Last Post: 02-20-2009, 04:15 PM
