585,555 active members*
3,482 visitors online*
Results 1 to 11 of 11
    Oct 2014
    5
    no pilot arc and cutting arc
    Hi everybody . i have some issue with my pilot arc. there is some problem with 400xd hypertherm.
    when i run the machine .the torch goes down touch the material making gas test and the machine doesnt cut the material
    no pilot arc and cutting arc .what does that cause about my problem. please help mee.
    Mar 2016
    323
    Re: no pilot arc and cutting arc
    The electrode, and cover are ok?
    The connector for high voltage (pilot arc) is clean?
    Oct 2014
    5
    Quote Originally Posted by steryd View Post
    I actually changed the consumable parts with new one. Rechecked the o2 and air.i got the pilot arc but i cant get the cutting arc.i have suspicious about my chopper board o the hypertherm unit
    Mar 2016
    323
    Check mass connector
    Oct 2014
    5
    i have attached you the video that you could figure it out .Thank you for your support...
    https://www.youtube.com/watch?v=jN4I...ature=youtu.be
    Mar 2016
    323
    Pilot arc looks fine, but stops very quick. Check air pressure and filters. There may be aproblem with hv set.
    Oct 2014
    5
    i am gonna check it out . thank you for your coorperation and support.
    Aug 2004
    104
    It would be good you rechecked the electrical conections between table and machine and then checked the Open Circuito Voltage for sure.
    Also check the parameters for pierce high.
    Mar 2016
    59
    Quote Originally Posted by Alex S.A View Post
    +1 and if those check out, check the spark gap.
    i found the problem. the problem was in the hose some copper from the watertube. it has been stuck inside the oxygen hose.i removed it and there was no any problem....
    Sep 2019
    54
    Hi I have same problem with ht2000
    Still can't figure it out,
  1. Pilot Pro By PDJ
    By hacksaw44 in forum Open Source CNC Machine Designs
    Last Post: 08-10-2013, 04:28 AM
  2. Pilot Pro Ex ???
    By gelaw in forum DIY CNC Router Table Machines
    Last Post: 03-19-2013, 06:24 PM
  3. PDJ Pilot Pro
    By hacksaw44 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2012, 07:30 PM
  4. THC with HV/HF pilot arc??
    By Fiero Addiction in forum Waterjet General Topics
    Last Post: 10-09-2008, 08:31 PM
  5. 3yr old Pilot
    By cncadmin in forum Hobby Discussion
    Last Post: 03-03-2006, 04:11 PM
