585,997 active members*
4,844 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Chamfer tool questions
    Dec 2016
    New here and pretty new to machining. I'm trying to put a chamfer around the edge of brackets that I have made. I'm doing all of this with FeatureCAM and a HAAS Mill. The chamfer bit seems to be following the correct path around the edge but it's a few tenths off of the edge of the material and not cutting at all. I'm trying to figure out what the issue is since I'm sure it's something I did and don't understand yet. We don't do much machining where I work and it's never very often and I'm learning as I'm going as well. What I wanted to start off with was how the tool was entered into the tool manager.
    The chamfer mill we are using is a 60* .25" from McMaster
    https://www.mcmaster.com/#3073a62/=15p3rz4
    The attached image is how I have it setup in the tool properties
    Is this correct?
    Re: Chamfer tool questions
    You need to put 30 degrees at the Angle Textbox according to the sketch at McMaster
    Dec 2016
    Thanks, that did the trick.
  1. Fusion 360 and general chamfer questions
    By Dallas J in forum Tormach Personal CNC Mill
    Last Post: 03-04-2016, 11:58 PM
  2. Chamfer Tool Path
    By warrguitars in forum MadCAM
    Last Post: 02-08-2012, 08:15 PM
  3. Chamfer Tool Question
    By MetalShavings in forum Solidworks
    Last Post: 09-25-2011, 04:06 PM
  4. Using a 45 deg chamfer tool
    By COPO427 in forum Mastercam
    Last Post: 01-14-2007, 07:28 PM
  5. What tool is best? Bevel/Chamfer
    By dneisler in forum MetalWork Discussion
    Last Post: 11-29-2005, 04:44 PM
