585,997 active members*
5,150 visitors online*
    Jun 2004
    8
    Ball screw load data
    Hello
    I am looking for help to understand Ball Screw Load data ..
    I'm upgrading milling machine which has a 3205 Ball screw .
    Examination of the data of 25 mm diameter screws with a pitch of 6 mm,
    Compared to 3205 Ball screw, I find that 2506 ball screw is better in terms of Static and dynamic data .
    What these figures mean?
    Attachment 345114
    y_shalom
    May 2013
    480
    Re: Ball screw load data
    static and dynamic load is in kilograms.
    the 2506 ballscrew uses larger balls, that's why it has a higher static load rating.
    Jun 2004
    8
    So what are the differences and benefits of using the 3205 ?
    What benefit of using the large diameter?
    The main question is
    Can I use 2506 instead of 3205 ?
    What will be the differences ?
    May 2013
    480
    Quote Originally Posted by y_shalom View Post
    32mm diameter is stiffer so more wear if the axis and ball nut not aligned. 25mm has larger balls so perhaps longer life when debris gets into the nut.
    32mm has much higher critical speed.
    The stiffness of the ball nut is similar in both cases but the 32mm screw is stiffer. So if you have a long screw that may be significant.
    32mm screw has higher critical speed but 25mm screw has 20% more lead, so max axis velocity is probably similar
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  3. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. Actual load on Ball Screw?
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 10-22-2004, 05:05 PM
