585,977 active members*
3,715 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Smooth Stepper on Novakon NM-200
Results 1 to 10 of 10
    Jan 2017
    I finally got a smooth stepper for my mill after 7 years. Finally got the axis working thanks to John's help over New Years weekend! I have no control of my spindle now. I spent the whole weekend messing around with settings and only managed to get the spindle to either go 100 RPM or 4000 Rpm. Does anyone that has a smooth stepper (ethernet) on their Novakon have any tricks or tip for settings? Also, I still have the momentary stop of movement from line to line as I was hoping to do away with by upgrading to the ESS.
    Feb 2006
    7063
    Re: Smooth Stepper on Novakon NM-200
    First, get the ESS installation manual from Novakon. It details every single setting to get everything working as it should.
    Second, if you are getting a stop between each line of g-code, you are almost certainly set for exact stop mode, which has nothing to do with the ESS. In Mach3, go to Config->GeneralConfig->MotionMode, and set it to Constant Velocity.
    Regards,
    Ray L.
    Jan 2017
    Thanks for the reply Ray. John from Novakon gave me the install manual and followed that to the T and I have my settings to constant velocity. Do I need a new XML file or should my existing one be working fine or do i need to modify it?
    Feb 2006
    7063
    The XML files in Mach3 do sometimes get clobbered in a way that they cannot be corrected, but must be either replaced with a good one, or reconfigured from scratch. Just one of the many joys of Mach3. I'd suggest getting a good XML from someone with identical hardware, or as close as you can get.
    John should be able to e-mail you one that should work.
    Regards,
    Ray L.
    Dec 2009
    594
    I have sent Dane a copy of my XML. We both purchased our mills at the same time.
    Feb 2012
    26
    sorry to dig this one up any chance one of you guys could send me the NM-200 ESS XML file too? Thanks in advance
    Apr 2017
    18
    kvom - I just purchased a lightly used NM200 R2 with ESS that had some electrical issues, and a pile of test .xml files the previous owner created/saved while debugging. If you had/have the same machine as mine, could I get a copy of the Mach23 configuration from you?
    Rick
    Dec 2009
    594
    Mine doesn't have an ESS, but I've attached XML file.
    Attached Files Attached Files
    Apr 2017
    18
    Thank you.
    Apr 2017
    18
    ignore
  1. Replies: 3
    Last Post: 08-08-2014, 02:01 AM
  2. Smooth Stepper, what do I need?
    By itko in forum SmoothStepper Motion Control
    Last Post: 02-19-2013, 10:16 PM
  3. Smooth Stepper Need Help
    By Mad Welder in forum SmoothStepper Motion Control
    Last Post: 09-24-2011, 04:21 AM
  4. Smooth Stepper
    By kingofl337 in forum SmoothStepper Motion Control
    Last Post: 08-19-2011, 03:11 AM
  5. Smooth stepper
    By dnelso in forum Charter Oak Automation Support Forum
    Last Post: 08-04-2009, 05:07 PM
