I'm new to running the CNC, I was working for a sign shop as a fabricator, and my hard work, ability to learn processes, and strong work ethic opened up the opportunity to learn them, so I'm taking on the challenge with less than two weeks time of training from the previous guy... He got me set up good for the most part but he couldn't show me everything, Been doing it now for a few months and every day is something new. with two machines, one 15 yo and the other 6yo, both love to surprise me. so now I'm here with this problem. . .
I'm having some trouble with my "multicam turbovac system" vacuum pump. I'm guessing its a heat issue. The pump will turn off during jobs. And inside the electrical box is a square control unit with a blue push button. Ill insert pictures below. First i noticed if i reset the button the vacuum will run back up. Then realized the cooling fan wasn't working. So thinking the problem was a temperature trip of some kind, I replaced the cooling fan. But now the fan doesn't come on and if I run the pump with the cover on, it heats up or the button trips and vacuum turns off.
Maybe someone can tell me what the dang box is or how I can find a manual on it, I've looked online and can't find ANYTHING with the numbers on the unit or the make model of the pump.
any help, words of wisdom helpful thank you for your time.
If need more pictures or info let me now, ill continue to problem solve myself.
Pics https://www.dropbox.com/sh/ysxftby9y...132qUTUja?dl=0
