585,942 active members*
3,586 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 - green light and holding torque but no movement
    Jan 2010
    76
    i decided to replace my hobbycnc controller with a G540 (no issues with the hobbycnc board, just wanted to try something different) and i got everything wired up and have a green light and have holding torque on my motor, but when i jog in Mach3, i get no movement. I haven't installed the G540 XML, but i changed the pins in the ports and pins section manually (i changed step and direction pin from 2 and 3 to 3 and 2 or vice versa and changed to active high, but other than that, the pin setup is similar between the hobbycnc and G540 boards). i was trying to not install the XML file because i didn't want to loose all my settings for my hobbyCNC board, which can still be hooked up.
    any ideas or things to check for why i have holding torque but no movement?
    35538
    Re: G540 - green light and holding torque but no movement
    Disable the charge pump on the G540.
    Mar 2013
    140
    You wouldn't lose your settings for the hobbycnc board if you used the g540.xml. You would just have the choice when starting mach3 of which profile you wanted to load.
    Jan 2010
    76
    Quote Originally Posted by manofmanyhats View Post
    Good to know, thanks!
  1. not getting the green light ?
    By bootleg in forum K2CNC
    Last Post: 03-05-2016, 03:47 AM
  2. g540 X-axis problem - Holding torque but no movement
    By rlockwood in forum Gecko Drives
    Last Post: 09-04-2012, 05:00 AM
  3. Holding torque vs rotational torque ?
    By SScnc in forum DIY CNC Router Table Machines
    Last Post: 05-06-2010, 01:41 PM
  4. G540 Green Light..Go or no go?
    By ronncat in forum Gecko Drives
    Last Post: 01-02-2010, 08:11 PM
  5. No holding torque or movement with G201
    By patdttr225 in forum Gecko Drives
    Last Post: 09-03-2007, 05:16 AM
