Re: What Happens If I Limit current to Bipolar Parallel motor less than rating
It you want more speed, worry less about amps, or bipolar/unipolar and more about voltage. Actually, unipolar will typically spin faster all else being the same, but voltage is more important. And watch out for mid band resonance, which is where the motors will run fine at high speeds (under light load) but then randomly stall and lock up at mid range speeds. To avoid that, use microstepping modes and add mass or resonance dampers. (e.g. a hockey puck with a hole in it on the shaft.)
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
