585,931 active members*
5,122 visitors online*
    Dec 2012
    52
    Buying a Pro408 review thread
    Hey all!
    1/8/2017
    I like starting these threads as they're what I look into when buying a new machine. The machine we just put a 50% deposit on is a Shopsabre pro 408 http://shopsabre.com/cnc-routers/pro-series.html. Just a small background on myself; my wife and I own a small 'home decor' shop that we started in our basement after hours that we ran on a small home built cnc I made (even a thread here somewhere) that now has expanded to a full shop with a few full time employees a real Techno ATC, few laser cutters (Thunder Laser) and now will be replacing the Techno with something faster.
    First Brandon has been great, I litterly started to bug him back in 2015 when I was going to go Omni due to the price. At this time I wasnt sure if I was going to do an ATC or a standard spindle. I was going to pull a trigger on the standard spindle as we needed a 4x8 router and not the ATC. A blessing came and a used Techno ATC came up on craigs for a killer deal and picked it up. Little did I know, ATC was going to alter our lives!) When I needed to replace the techno, I knew Shopsabre was my choice after I narrowed them down back in 2015 and my long discussions with Brandon. They had a great price with the ATC, new vacuum system, and a killer machine with some good promos! We got the 408 spec'd out and ordered with all the bells and whistles at still a great price.
    I'll update the thread when anything worth while happens but I hope this thread helps future CNC router customers find the right CNC for them and learn from the good/bad (fingers crossed) that I went through!
    Thanks!
    2015 - starting bugging Brandon at Shop Sabre when I was debating a Omni or Shop Sabre
    2015 but bit later - Found a used Techno ATC on craigs
    Mid 2016 - start maxing out Techno machine
    12/6/2016 - Put a 50% deposit on a ShopSabre 408 ATC with most all options, estimated lead time is 4-8 weeks, should put ship date 2/6 ish.
    Jul 2008
    Re: Buying a Pro408 review thread
    How is your shop sabre working out?
  1. Thread forming vs thread cutting in plastic
    By BitMag in forum Mechanical Calculations/Engineering Design
    Last Post: 12-02-2016, 12:24 PM
  2. Buying a machine soon..any tips before buying?
    By TSHobbies in forum PlasmaCam
    Last Post: 11-09-2016, 03:22 PM
  3. Thread spec for camera lens filter thread
    By cmays in forum MetalWork Discussion
    Last Post: 07-20-2016, 10:43 AM
  4. Thread Mill Wizard - Slanted thread produced
    By ngr1 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-22-2012, 07:23 PM
  5. acme thread combos and thread mixing
    By calaber40 in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 02:04 AM
