585,975 active members*
4,971 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > What coolant do you use in your water cooled spindle?
Results 1 to 6 of 6
    Nov 2006
    1036
    Just about to set up my first water cooled spindle and I'm confused about what I should use for coolant. It will be a closed system with a small radiator coolng a 1.5 kW spindle.
    Would you more knowledgeable and experienced folks share what you use in your spindles?
    Sep 2011
    41
    Re: What coolant do you use in your water cooled spindle?
    Artic Flu -5
    May 2015
    1422
    Aluminium compatible automotive coolant.
    Aug 2014
    22
    Automotive coolant
    Sep 2011
    41
    I was once warned that automotive coolant has additives in it to prevent leaks, these can cause problems when used in systems with small csa circuits.
    Mar 2010
    813
    I used cheap automotive 50/50 coolant for over a year with my Swiftech radiator/fan that rides along behind spindle. I read some negative feedback on automotive coolant and replaced with the cpu coolant (link below). The automotive coolant was same color as the day I put it in a year later when drained . Been almost another year with cpu coolant and still red in clear tubes. Great set up and highly recommend, only regret is I wish I made my fan filters more easily accessible to clean. Spindle goes 2-3 hours with 3d work and just gets warm to touch. Seen no difference for either coolant other than the price difference.
    EKWB EKoolant Premixed Blood Red Coolant 1000mL 735688 - Micro Center
    Dan
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water pump for water cooled spindle
    By bballish in forum DIY CNC Router Table Machines
    Last Post: 03-01-2016, 02:40 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. Water cooled spindle, what coolant do you use
    By TSJ in forum DIY CNC Router Table Machines
    Last Post: 05-30-2013, 12:46 PM
  5. Should I refrigerate my water cooled spindle coolant?
    By davtuner in forum DIY CNC Router Table Machines
    Last Post: 02-09-2012, 06:56 PM
