585,727 active members*
4,046 visitors online*
Thread: New Build
    Jul 2008
    New Build
    OK this is my first post ,This is not my first cnc machine , in the past I had a Shopbot , The past 2 months I purchased parts on Ebay for this build ,
    4 Nema 23 motors ,2 34 volt power supply's and one 48 Volt for the Z
    SBR16 liner rails and 1605 ball screws
    8020 T slot Aluminum
    3 axis 1/2" plate kit for gantry , Z plates and motor mounts
    Smooth stepper board ESS and a BOB from CNC4PC that plugs directly into the smooth stepper
    MACH3
    1.5KW Spindle water cooled with heat ex changer
    Over the past 2 months I have been assembling the parts and testing , did some reading on this forum "machine build BIG BAMBOO" got a lot of good info there ,
    assembled most of the machine and at that point I decided I did not like the outboard ball screws as they were getting dusty just during the build , so came up with the idea to rotate the plates 90 deg , cut off what was not needed , added a cross plate between the lower gantry , and I am quite satisfied so far , have made some test cuts , and kinda getting the hang of MACH3 , I am now waiting on 2 timing gears and belt for the two Y axis motors as I can see the need for them , and a brush from Kent dust shoe , I cut my own plexi dust shoe just like Kent makes with the magnets , waiting for the brush to surface the table , I put 1/4-20 inserts every 2" into the spoil board , have also installed home sw and limit sw Attachment 346916
    Jul 2008
    Jul 2008
    Re: New Build
    Oct 2005
    612
    Re: New Build
    Nice build and attention to detail
    Thanks for posting
    cheers,
    Rod
    Perth, Western Australia
    Feb 2019
    7
    Re: New Build
    Thanks for posting and nice build - how's the machine running? I appreciate your insight to having outboard screws and collecting dust. Any further modifications?
  1. Build Thread - 80/20 5X10 Woodworking CNC Build
    By jsantos in forum CNC Wood Router Project Log
    Last Post: 08-20-2014, 03:15 AM
  2. Replies: 3
    Last Post: 01-05-2013, 05:24 AM
  3. Mint's Build Aluminum/Steel Build thread.
    By FreshMint in forum Maintenance DIY Discussion
    Last Post: 10-31-2011, 04:18 AM
  4. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
