585,982 active members*
4,648 visitors online*
    Jul 2016
    Gantry Dimensions
    Hello,I am in the process of building a 5x10' water plasma table, I've been following as many builds as I can, however I could really use some help on finalising a few questions about the gantry...
    Dimensions of the end plates, I plan to copy others with a piece of 1" aluminum on each end of a 3"x3" (thinking 3/16th) square tube. I'd like to keep the gantry as small as possible, I have a piece of 1" x 12" x 12' aluminum to work with, I realize 12" is a little narrow, but the price is right.
    How high above the table would you recommend? I am thinking about 8" from the bottom of the square tube to the slats of the table.
    Thanks for your time!
    Mar 2016
    59
    Re: Gantry Dimensions
    Quote Originally Posted by Lostbendix View Post
    You really don't have enough information here. While I gather that your cross axis beam is going to be made from a 3/16" x 3" x 3" square tube (which I myself find to be a bit small) you have not mentioned the trucks or the station that will be mounted to the beam. How far below the beam does the station protrude? What is the stroke of the lift? What torch will you be using?
  1. Gantry mill with moving gantry for Z-axis
    By rogue-insight in forum Vertical Mill, Lathe Project Log
    Last Post: 09-07-2020, 01:32 PM
  2. Need thoughts and ideas on changing a single sided gantry to 2 sided gantry...
    By RECELECT in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-17-2016, 07:49 PM
  3. help dimensions of hitorque x2 dimensions?
    By Winterwatchers in forum Benchtop Machines
    Last Post: 04-17-2014, 03:35 PM
  4. Fixed gantry vs moving gantry
    By scott0999 in forum DIY CNC Router Table Machines
    Last Post: 01-31-2014, 06:14 AM
  5. Gantry: planning to design moving open gantry
    By rdcd in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2009, 10:52 PM
