585,705 active members*
4,064 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Possible sheetCAM problem, no charp corners?
    May 2015
    Helo.
    I have a home built plasma table, with Candcnc electronics using mach3 and sheetCAM.
    For some time now I have had the problem with my machine when cuting thinner material fast. The problem is that some of the 90 degree corners in the part gets a huge radi. I have search for a solution but not find any, so i am writing here in search for your experties.
    thankful for any input, I will attach an image of a part i did so you can se what i mean!
    Regards Edwin
    ps. You can se that every (supposed to) sharp corner in the letter have a radia ds.
    Aug 2004
    244
    Re: Possible sheetCAM problem, no charp corners?
    It may be a controller setting issue. I don't use Mach 3 any longer but I do recall it has an exact stop mode and constant velocity mode with some setting for tolerance. Those may not be the names for the setting but they should be something like that. On the Cam side you can set G61 or G64 to control what mode the controller is in. G61 is exact stop and G64 is the constant velicty mode.
    Everything in moderation, including moderation.
    Jan 2011
    188
    yep - constant velocity - you either have to turn CV off - or decrease feedrate, and/or increase acceleration, and/or set CV distance to a tolerable radius (which will cause the machine to slow down for corners without exactly stopping)
    www.signtorch.com
  1. problem with sheetcam and NCstudio
    By inhamed in forum SheetCam
    Last Post: 04-03-2015, 04:04 AM
  2. Replies: 4
    Last Post: 03-04-2015, 11:02 AM
  3. Precix running with Mach3 gcode, problem in edges and corners
    By FABLABBARCELONA in forum Commercial CNC Wood Routers
    Last Post: 12-29-2014, 05:49 PM
  4. Replies: 1
    Last Post: 02-03-2014, 12:07 PM
  5. problem with z in sheetcam
    By nic6911 in forum SheetCam
    Last Post: 10-02-2010, 01:45 PM
