585,992 active members*
5,238 visitors online*
    Jan 2017
    Syntec RPM problem
    Hi all!
    I'm having trouble with the spindle rpm on a new syntec 6ma. I can't get get the actual speed to go any higher than 2000
    rpm even if I've set the speed to 14000 rpm. Does anyone know what the problem could be?
    Oscar
    Aug 2009
    655
    Re: Syntec RPM problem
    Quote Originally Posted by oscarsodergren View Post
    Hi all!
    Oscar
    What does parameter 1671 say. I believe it 0 to 10v on the controller so it should be 1/10th of your max rpm. Also 1801 should be at max speed of spindle.
    Rem password is 520 to change.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  1. Syntec 20A-6E
    By Roctech-Mercy in forum Roctech CNC Routers
    Last Post: 10-24-2015, 07:23 AM
  2. Syntec CNC
    By KHOATRANNGOC in forum Chinese Machines
    Last Post: 01-02-2014, 05:12 PM
