585,937 active members*
3,999 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > 2007 hurco vm1 not powering up completely
Results 1 to 8 of 8
    Jan 2017
    8
    Hello to all , I am having a problem where my machine switches on ,screen comes to life but has a line that flickers , I press manual then power and you can hear the contactor clunk but you can go no further , if you press input programming the little marker just scrolls continuously from top to bottom , I cannot get onto manual screen to reset servo etc. when I open the rear cabinet door on the servo I can read bb flashing and base block , it also shows bb on the three servo drivers, I have tested the power output I read about on one of the posts I read ,( the little white posts )and I am not getting 5volts and all other readings are about .5 of a volt down. it has a max control I forgot to say, any advice would be very much appreciated. ps. this is my first post so fingers crossed I have got it right.
    Nov 2006
    473
    Re: 2007 hurco vm1 not powering up completely
    Does it have a card rack for the boards?
    Jan 2017
    8
    I AM TRYING TO REPLY BUT NOT HAVING A LOT OF LUCK , I THOUGHT I COULD SEND YOU A PICTURE AS I AM NOT SURE WHAT YOU REFER TOO,
    Oct 2004
    188
    little marker scrolling from top to bottom indicates a stuck enter key or arrow key on the keypad or qwerty keyboard if you have one plugged in.
    resolve that first then we can move on to the next problem
    No 5 volts at the test point but the machine screen is up indicates that the test point is bad. it happens a lot people short it out when testing to the case. it blows the little trace for that test point open. You can check your 5 volts on the hard drive power connector.
    Jan 2017
    8
    I DO NOT HAVE A KEYBOARD PLUGGED IN AT PRESENT AND I DO NOT KNOW HOW I CAN CHECK THE INPUT BUTTONS ON THE MACHINE AS THEY ARE JUST LITTLE BLISTERS ON MAX KEYPAD. THE FLICKER STILL REMAINS AND I CANNOT GET TO THE MANUAL SCREEN TO RESET.I WILL GIVE SOME MORE PICTURES OF SCREEN AND CABINET INTERNALS IN CASE IT HELPS LET YOU OR SOMEONE SPOT SOMETHING.
    Jan 2017
    8
    Just a word of thanks to Scrambled and Powerr for answering my call for help, it was as powerr stated a fault with the keypad , it turned out water or coolant had got between the membrane and the contacts and over time had started to corrode , but cleaned it well and all is satisfactory now .
    so thanks again to all on the forum . msrath
    Oct 2004
    188
    Good deal. Glad you got it going.
    Jan 2017
    8
    hi powerr, do you have any experience with 2008 /tm8 lathe
  1. Completely Different
    By allesg in forum Epoxy Granite
    Last Post: 05-16-2011, 02:34 AM
  2. completely new to this
    By superrican in forum DIY CNC Router Table Machines
    Last Post: 02-04-2009, 12:47 AM
  3. need mc 8.1 post for 2007 hurco
    By timmyv in forum Post Processors for MC
    Last Post: 10-08-2007, 05:06 PM
