585,949 active members*
4,381 visitors online*
    Nov 2010
    39
    Mazak post for mill turn
    I am either purchasing a Mazak sqt15ms with c axis and subspindle with t-32-3 control does not have EIA enabled or an Integrex with tplus control, EIA option enabled, c and y axis / tailstock. I currently use Inventor with HSM. The only other CNC machine I have at the moment is a Milltronics VM17. I am trying to figure out the best method or getting a post for one of these machines.
    I like the Integrex but I am worried it is to much of a machine for me to start out on. I only have manual lathe experience and only about 6 months of cnc on the mill.
    Dec 2013
    5717
    Re: Mazak post for mill turn
    I would contact HSM support at AutoDesk, they are normally very responsive in helping and creating post processors for various machines.
    Nov 2010
    39
    I ended up getting a sqt18m with t plus control. I have emailed autodesk but they did not have one. They did mention someone was working on a post at one point.
    Mar 2014
    44
    We created a postprocessor for the Integrex that runs very nice, but as I read, that too late now. Good luck with your new machine.
  1. Postprocesor for mazak integrex turn mill
    By zarif in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-05-2017, 04:20 AM
  2. Replies: 0
    Last Post: 04-01-2016, 07:52 PM
  3. Replies: 1
    Last Post: 04-14-2014, 07:49 PM
  4. Turn/mill between spindles Mazak i-200S Matrix II
    By chartwar02 in forum G-Code Programing
    Last Post: 02-28-2014, 02:05 PM
  5. turn on part counter in eia on MAZAK nexus vertical mill
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-31-2008, 03:49 AM
