585,973 active members*
4,192 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Getting the CD servostar enabled
Results 1 to 9 of 9
    Sep 2006
    177
    I have a Servostar CD CE06250 AC brushless servo drive and am having trouble getting it to enable. The only condition that isn't met is the hardware enable. The manual says that a 12 to 24VDC external signal is required. I got that, attached the low wire to ground and the 24V to pin7 on connector3, then shorted pins 7 to 8 on connector3 (which should enable the hardware). Maybe there is some trick that i don't know.
    My other guess is that a fuse is blown somewhere in the drive (this drive may have been previously used).
    Sep 2006
    177
    Never mine, i figured it out. 24V return goes to remote enable pin (pin8) the positive goes to pin 7.
    24221
    It appears to me that Conn 3 should be +24 on 7 & pin 8 is enable, that should be connected to 24vcom.
    Also usually all the motor phasing WRT the commutation has to be correct before the drive will enable.
    Ooops, I see you found it.
    Al.
    Albert E.
    Feb 2008
    Hi Mackeym
    I bought 3 servostar CD and 3 Servo motors for my CNC project without MotionLink software. I am new starter. Could you tell me what need to be done first.
    Thank you very much.
    Thai vu
    Jun 2010
    4
    Here is the link to the Motionlink software, from Kollmorgen.
    You will need a com port. If you are using a laptop with only usb ports you need a usb to serial adapter. They are cheap.
    Download all the software they offer and use what you need to begin using it.
    Have fun...
    http://www.kollmorgen.com/website/co...e_firmware.php
    Oct 2005
    255
    I also have one of these units
    manual. ?? are you able to share this information?
    Thanks in advance
    Paul
    Jun 2010
    4
    Quote Originally Posted by paul3112 View Post
    Thanks in advance
    Paul
    Here is the link for the installation manual.
    This should answer most questions, let me know...
    Make sure your feedback and power cables for your motor are correct.
    http://www.kollmorgen.com/website/co...es_manuals.php
    Oct 2005
    255
    Thanx Papa
    looking around that link I found
    http://www.kollmorgen.com/website/co..._documents.php
    Series 2 being of interest for the model I have.
    Paul
    Sep 2010
    1765
    series 2 is just the older control card version; newest is series 5 (so CE06-550 insterad of CE06-250). it should be transparent to you and all manuals will give enough enough info for you for either.
