585,902 active members*
4,317 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > CNC for mini-lathe by SIEG (Micro-mark, HF, etc)
Results 1 to 8 of 8
    Feb 2007
    6
    Hello All,
    As you mini-lathers probably know, the mini-lathes supplied by Micro-Mark, Harbor Freight, Grizzly, Homier and others are all made by the SIEG company in China. Sieg paints them to spec for the retailers and does some customization, but basically, these lathes come from here: http://www.siegind.com/Products/blackred_lathe.htm
    My thread involves getting a decent CNC kit for these lathes. I don't even mind buying motors and making brackets myself, and buying a separate controller. These lathes don't have ballscrews, and the stock screws aren't real smooth, so oversizing the motors or gearing them down would be a good thing to discuss. It would be nice if someone has an alternate solution to hanging a big stepper motor off the tiny little cross-slide on these little lathes.
    Also, I'm thinking about automating the tailstock for automated drilling and am looking for ideas on how to best motorize the tailstock.
    Happy Turning,
    John.
    Aug 2006
    161
    Id be interested in any idea people come up with alsi as I just bought a Sieg C3
    DJH
    Sep 2004
    145
    Try here:
    http://www.stirlingsteele.com/latheplans.html
    I converted mine with these plans and a HobbyCNC driver kit. I use Mach3. Works real well together.
    I want to do the motorized tailstock too, but I haven't given it a lot of thought yet
    HTH
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Quote Originally Posted by mark c View Post
    Try here:
    HTH
    Can you post a few pictures of the motor mounts and parts you made?
    I want to do the same setup but would like to see one before I purchase the plans.
    Bill
    Bill
    Sep 2004
    145
    There are some pics here that show the mounts without a lot of detail, but you can get the idea.
    http://www.mcoates.com/cnc_lathe1.html
    I'll try to get out and take some better ones later today
    Mark
    www.mcoates.com
    Sep 2004
    145
    These give you a better idea about the mounts. Nothing is terribly difficult
    HTH
    Attached Thumbnails Attached Thumbnails cross slide mount.jpg   lathe endplate.jpg
    Mark
    www.mcoates.com
    Hello mark,
    Yes, that does help. What size of screw have you added for the Z axis?
    Bill
    Bill
    Sep 2004
    145
    It's a 3/8"-8 acme 2 turns per inch
    Mark
    www.mcoates.com
  1. Sieg C3 mini lathe - My shot at a CNC conversion
    By Guldberg in forum Vertical Mill, Lathe Project Log
    Last Post: 08-29-2007, 08:20 PM
  2. Micro Mark upgrade problems
    By SPEEDRE in forum Mini Lathe
    Last Post: 02-10-2007, 04:42 PM
  3. Traveling to China, looking for a micro/mini lathe
    By Konstantin in forum Mini Lathe
    Last Post: 11-19-2005, 05:19 AM
  4. Micro Mark
    By xa_shall in forum Mini Lathe
    Last Post: 11-10-2005, 11:24 PM
  5. Micro Mark Mini mill converstion
    By cncadmin in forum Vertical Mill, Lathe Project Log
    Last Post: 02-08-2005, 04:27 AM
