585,917 active members*
3,310 visitors online*
IndustryArena Forum > CAM Software > Vectric > calling on experts
Results 1 to 7 of 7
    Nov 2014
    74
    Question calling on experts
    Is there anyway to bring this graphic into aspire and create a tool path to cut it out I have a friend that asked if i can cut this out
    Thanks all
    Feb 2012
    8
    Re: calling on experts
    If you have the original drawing, it looks to be a v-carve operation with the cut depth set to the depth of the flat area...if you mean cut out as in cutting around it to remove it, I think again if you have the original drawing, you could use a profile cut with a small (1/8" bit in order to get better detail...not sure if that is what you need.
    Nov 2014
    74
    Quote Originally Posted by riggsp View Post
    No I only have this picture I have tried to convert it many times and many different ways but I never get a good result
    To make a tool path from
    Feb 2012
    8
    Only other solution I have, since it is a jpeg file, import the file as a bitmap then trace it on another layer...you can use node editing to move the lines after you do a rough trace...it's a time taker, but that is the only way I can figure to do that without the original drawing.
    Apr 2009
    5516
    You might be able to edit this in Photoshop or something (GIMP maybe), remove the surrounding area, convert to black and white, and use that as a height map to make an STL file. There's tutorials on how to do it with freeware online, though I've never tried it myself.
    Apr 2008
    204
    you could dry doing a rub with a crayon and paper, that may give more contrast when you do a bitmap trace in v carve.
    Apr 2009
    5516
    Some quick research, and this is a logo for Old Vienna Beer. Y ou probably could recreate this with online artwork of the knight, and a font close enough....
  1. Calling all exotic wood experts
    By Doug Kramer in forum WoodWorking Topics
    Last Post: 04-20-2016, 05:55 AM
  2. Calling All Experts
    By buffmasterbran in forum Want To Buy...Need help!
    Last Post: 08-09-2011, 09:07 PM
  3. Getting a radius'd edge. Calling all experts
    By Lou Anderson in forum Wood Lathes / Mills
    Last Post: 07-04-2009, 04:40 PM
  4. Calling all stamping experts
    By skippy in forum Uncategorised MetalWorking Machines
    Last Post: 10-12-2008, 10:08 PM
  5. Calling on experts to help spread your knowledge
    By Swiss in forum Community Club House
    Last Post: 07-28-2007, 12:58 AM
