585,959 active members*
3,961 visitors online*
    Jan 2017
    Value for DIY CNC 3 Axis Engraver is lost
    I have a DIY Mini 3-Axis CNC Router Engraver Carving Machine for PCB PVC Milling Wood Y
    and a lost the original value for setup
    My setup is looking like this:
    [CTRL+X] < Grbl 0.9j ['$' for help]
    $$ < $0=10 (step pulse, usec)
    $1=25 (step idle delay, msec)
    $2=0 (step port invert mask:00000000)
    $3=0 (dir port invert mask:00000000)
    $4=0 (step enable invert, bool)
    $5=0 (limit pins invert, bool)
    $6=0 (probe pin invert, bool)
    $10=3 (status report mask:00000011)
    $11=0.010 (junction deviation, mm)
    $12=0.002 (arc tolerance, mm)
    $13=0 (report inches, bool)
    $20=0 (soft limits, bool)
    $21=0 (hard limits, bool)
    $22=0 (homing cycle, bool)
    $23=0 (homing dir invert mask:00000000)
    $24=50.000 (homing feed, mm/min)
    $25=635.000 (homing seek, mm/min)
    $26=250 (homing debounce, msec)
    $27=1.000 (homing pull-off, mm)
    $80=0 (diy8000 data1,int)
    $81=0 (diy8000 data2,int)
    $82=0 (diy8000 data3,int)
    $83=0 (diy8000 data4,int)
    $100=314.961 (x, step/mm)
    $101=314.961 (y, step/mm)
    $102=314.961 (z, step/mm)
    $110=800.000 (x max rate, mm/min)
    $111=800.000 (y max rate, mm/min)
    $112=350.000 (z max rate, mm/min)
    $120=50.000 (x accel, mm/sec^2)
    $121=50.000 (y accel, mm/sec^2)
    $122=50.000 (z accel, mm/sec^2)
    $130=225.000 (x max travel, mm)
    $131=125.000 (y max travel, mm)
    $132=170.000 (z max travel, mm)
    I do not know if the values are correct.
    Here is my problem:
    I have a rectangle 140 x 110 mm (artcam pro)
    but after finsh work (engraver) the dimensions is smoller: aprox. 55 x 45mm
    Why?
    Can someone help me?
    Apr 2016
    102
    Re: Value for DIY CNC 3 Axis Engraver is lost
    You have got a 2,54 scaling error there, something to do with settings for inches.
    Barrie
    Barrie @ Composite Specialities Ltd. using BobCAD V29 Mill 3 axis Pro, Geomagic Design, Bricscad V16 and MOI V3
    Feb 2017
    17
    Write down the current values for 100, 101 & 102....then change them to 800. Those are the values that worked for my eBay special, now moving to correct scale. CAD-up something like a 50mm box to test and tweak the rates until profit.
    Sent from my SM-G900V using Tapatalk
  1. Gecko G540 4 axis lost torque on 2 axis - help please..
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 07-20-2015, 10:36 PM
  2. need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
    By lkasdorf in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2013, 02:50 PM
  3. Lost the X axis
    By rocko in forum Larken
    Last Post: 03-10-2013, 06:19 PM
  4. Lost 4th Axis
    By patveth in forum Xylotex
    Last Post: 10-27-2009, 06:38 PM
  5. 0T X-axis Gets lost
    By John3 in forum Fanuc
    Last Post: 08-27-2007, 11:34 PM
