585,937 active members*
3,983 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Need help with 3040 CNC & Mach3 Settings.
Results 1 to 14 of 14
    Sep 2016
    7
    Hello!
    I new in CNC, Can someone help me with settings on Mach3 and 3040 CNC. When I connect this CNC to my computer and open Mach3 my CNC can move only on Z axis and Y axis. This machine with a parallel port, I use UC100 CNC motion controller for connecting to USB on my laptop Windows 10.
    Thank you for your help.
    Stan
    Aug 2006
    44
    Re: Need help with 3040 CNC & Mach3 Settings.
    Hello Stan ,
    where are you located ? I am in Los Angeles.
    I can help you .
    you can contact me by my email .
    [email protected]
    Sep 2016
    7
    I'm in Brooklyn NY
    Apr 2004
    5737
    What happens if you attach the leads from an axis that works to the X axis? If it comes to life, then it might be that your pin assignments are incorrect. If not, then you might have a bad cable or connection.
    Andrew Werby
    Website
    Sep 2016
    7
    yes, if I attach the leads to X-axis, X-axis work.
    Sep 2016
    7
    I still need help. Please!
    Apr 2004
    5737
    These machines often ship with incorrect information about which pin goes where. See if you can find a correct pin-out. If that's not the problem, you might have a bad cable, a bad connection, or a bad drive. None of these are particularly uncommon. Replacing the whole control system with something decent usually makes these machines work a lot better.
    Andrew Werby
    Website
    Sep 2016
    7
    Quote Originally Posted by awerby View Post
    What control system do you recommend?
    Thank you.
    Apr 2004
    5737
    The consensus choice around here is the Geckodrive G-540, which combines the functions of a breakout board and 4 drives: G540 4-Axis Motor Control | GeckoDrive . Give it a 48v power supply, mount it on a heatsink with a fan, and your machine will likely work a lot better.
    Andrew Werby
    Website
    Apr 2013
    1899
    Quote Originally Posted by sts2710 View Post
    Hello!
    Is it a REAL UC100 or a fake? There are a lot of fake ones on eBay, read this post:
    http://www.cnczone.com/forums/uccnc-...20228-cnc.html
    If your UC100 is real than you should have no problems with that. However, probably you need to follow the manuals. Download the UC100 manual from here:
    http://cncdrive.com/MC/UC100%20datas...rs%20guide.pdf
    ...but you also need the Mach3 manual to configure the pins. You must also know how your CNC is wired.
    Don't start buying drivers or other stuff before you are ABSOLUTELY sure that you must and before you actually identified the problem. It is most probably just a question of configuration or some wiring. Maybe the X step or enable signal is lose or broken.
    Apr 2013
    1899
    Why give him this advise at this stage? Also, what sort of "consensus" are you talking about? There are many alternatives to Gecko, but regardless of which, it is not time for him to decide on that right now. In which way would he be helped if he ripped out everything and replaced it with something new without knowing what is wrong? How do you know it is not a stepper that is broken, or just as simple as a lose wire?
    Apr 2013
    1899
    Thank you.
    Don't throw money out the window unless you have too much of it...
    Find out what's wrong first before you waste a few hundred $$$ and many hours on something you don't need.
    Sep 2016
    7
    Quote Originally Posted by A_Camera View Post
    Thanks for the reply,
    UC100 original. I'm going to check all your recommendations.
    Stan
    Sep 2016
    7
    Problem solved!
    Thank you!
  1. 3040 t d axis settings
    By Janste in forum Chinese Machines
    Last Post: 01-10-2015, 05:22 PM
  2. Home switches in yoocnc CNC 3040 with Mach3
    By dudeja28 in forum Chinese Machines
    Last Post: 06-11-2014, 02:41 PM
  3. Probe Pins Mach3 ,3040
    By Littlemango in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2014, 05:47 AM
  4. Rabbit 3040 laser cutter with Mach3 ??????
    By Mrebeiro70 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2009, 03:38 AM
  5. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
