585,766 active members*
4,468 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Magnum II HD gantry fab- 4" channel flush with tabs?
    Dec 2011
    9
    I'm having trouble deciphering what this means on the plans. Does it mean there should be a 4 inch piece of channel welded between the gantry plates? Tech the motors or something? I don't see the tabs on the side plates. Thanks in advance
    Jan 2014
    28
    Re: Magnum II HD gantry fab- 4" channel flush with tabs?
    from the looks on the plans they are angels welded on the inside post likely to stiffen the bottom since there is no bottom they should be on the cut sheet to make you can always ask persision plasma an email
    just red the bottom turn over and weld in channel 4 inch or 5 inch you must make keep below motor hole not lower then the bearings on the rail
    Dec 2011
    9
    Thanks for the reply. I messaged Ron and that's it. C-channel welded in under the stepper motor to reinforce the bottom. Glad I haven't painted it. Lol
    Oh, and if anyone follows me, it's been with the tabs on the end that carry the front and rear bearings.
  1. Outline "tabs" with KiCad and pcb2gcode
    By fishface in forum PCB milling
    Last Post: 05-30-2022, 04:35 AM
  2. Replies: 0
    Last Post: 06-07-2016, 01:19 PM
  3. MAGNUM CNC PLASMA GANTRY KIT
    By mchachi14 in forum News Announcements
    Last Post: 10-29-2015, 06:01 AM
  4. Can V9 leave "tabs" to hold parts?
    By juxtoposed in forum Mastercam
    Last Post: 03-26-2010, 08:48 PM
  5. Lube channel flush??
    By zoeper in forum Uncategorised MetalWorking Machines
    Last Post: 05-23-2006, 05:54 PM
