585,722 active members*
4,069 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > LAser cutting machine makes a wave in a corner at the time of cutting
Results 1 to 11 of 11
    Jan 2017
    7
    Dear friends
    I have a problem my laser cutting machine makes a wave in a corner at the time of cutting.
    This problem is even more when the speed is increased and cuts are small.
    Please I need your help to solve this problem
    Sep 2011
    41
    Re: LAser cutting machine makes a wave in a corner at the time of cutting
    Check the backlash in your X and Y axis drives.
    Jan 2017
    7
    Hello Miz
    First of all thanks for your soon response.
    How and where Can I check that?
    Please help me.
    Thank you in advance.
    Jan 2017
    7
    Quote Originally Posted by Miz View Post
    Hello Miz
    Please help me. The sofware is Lasercut
    Sep 2011
    41
    Your machine has a gantry, can you move it by hand, when you do, can you feel a slight knock when you start/stop.
    Then try the same when moving the head on the gantry.
    When you identify where the play you need to adjust your machine, if you have no play, then we need to look for another cause.
    What is the machine, how do the axis move, has the problem suddenly appeared?
    Nov 2008
    644
    If the photo were taken equal to how it was cut (x is right left) and (y is up down) then it appears the cut direction was counterclockwise. so whenever it changed direction from x to y the wave showed up. So lower right moves left then proceeds up and you get the wave. go from upper left move right and turn down you get the wave.
    That means the x axis is acting like a spring or rubber band.
    So there is something is loose in the pulley to the stepper or pulley to the belt or the belt is sagging and whipping. You probably need to tighten everything up.
    The only other thing could be mirrors are moving. Probably the mirror above the lens. meaning the mirror mount is swaying when it stops abruptly. Just tighten stuff up.
    if all fails to correct, changing speeds might reduce but not eliminate it.
    Some machines are poor quality and replacing components is the only answer. Good luck
    Jan 2017
    7
    Arrow Re: LAser cutting machine makes a wave in a corner at the time of cutting
    Quote Originally Posted by Dean448 View Post
    Hello Dean
    Thanks for your soon response.
    It could be when we had to changed the belt because it broked when we tried to put it again, after we changed the slider.
    We repared it but could it cause the problem? How can I adjust the belt? It is difficult to put it in the right place.
    Can it adjust with the stepper motor?
    What do you suggest?
    Thanks for your response in advance.
    Jan 2017
    7
    Hello Miz
    The problem could started when we repaired the belt because it broke when we tried to put in again after changed the slider.
    If I buy a new belt How can I put it right because it was difficult to put it in the right place and it was the main cause for it to break because it could not be adjusted in the slider.
    Can the belt adjust with stepper motor?
    Nov 2008
    644
    The only way to tighten the belt is to spread pulleys apart or pull the belt down using an idler pulley. It should be stretched reasonably tight but not so tight that the belt no longer tracks properly on the pulley. The belt can't ride up the side of the pulley.
    Sep 2014
    7
    Jan 2017
    7
    It is a Laser Cutting Machine 1400*900 mm, Laser tube 100 W. Company: Jindiao
  1. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  2. best choice steel sheet cutting machine fiber 500w laser cutting machine
    Last Post: 07-22-2015, 08:46 AM
  3. Laser cutting machine in daily work needs to maintain what time is it?
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-26-2014, 08:21 AM
  4. Cutting Quality Makes TubeTailor I Tube Cutting Machine Stand Out
    By Steel Tailor in forum Other Machine Topics
    Last Post: 05-09-2014, 08:41 AM
  5. Cutting Quality Makes TubeTailor I Tube Cutting Machine Stand Out
    By Steel Tailor in forum News Announcements
    Last Post: 04-18-2014, 02:17 AM
