585,973 active members*
4,139 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > TELWIN SUPERIOR PLASMA 160 - STEELTAILOR SMART III
    Feb 2017
    The superior Telwin Plasma 16 (inverter) has a voltage of 10-300 volts output and SteelTailor smart III needs a 50-300 volts the problem is that it does not work the torch height control .. can anyone help me?
    thank you
    REAR PANEL plasma
    PIN 1 Polarizer
    PIN 2.3 MODBUS Rs485.
    PIN 4.5 Cutting arc contact. Normally open, it closes when thecutting arc is enabled. PIN
    6.7 Pilot arc contact. Normally open, it closes when the pilotarc is enabled.
    PIN 8 External power enabling command. If closed at 0[V]
    (PIN12) it will enable power. It completely replaces the torchbutton function.
    PIN 9 Voltage OUT signal. Range 0-10[V] with settable range10V/200V, 10V/300V, 10V/400V, 10V/500V. The setting requiressimultaneous pressing of the “Encoder and Select Mode”buttons when the card is booted. Select the desired range usingthe encoder. Press the “select mode” button again to exit. PIN10 Current setting IN signal 1[V] / Imax/10 [A].
    PIN11 Air pressure OUT signal 1 [V]/[BAR] range 0..10 [V] PIN12 Reference 0[V] signals PIN 8,9,10,11 and 13.
    PIN13 Power supply 12[V] max 100mA.
    PIN14 PE protective conductor.
    Re: TELWIN SUPERIOR PLASMA 160 - STEELTAILOR SMART III
    Hi Pillos. Sorry to reply you late. Could you pls email at [email protected]? Our technical Service manager will reply you today. Thank you for your patience . Nice day for you!
    SteelTailor--The world leader of portable CNC cutting machine
    www.steeltailor.com
  1. SteelTailor Plasma Nozzle is getting damaged at the first pierce itself?
    By Steel Tailor in forum Other Machine Topics
    Last Post: 05-25-2015, 10:22 AM
  2. Replies: 1
    Last Post: 06-16-2014, 08:15 AM
  3. who test telwin plasma please help me
    By rimawi2008 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-06-2011, 10:24 PM
  4. New steeltailor Bench CNC Plasma cutter
    By denniswang in forum News Announcements
    Last Post: 07-21-2010, 07:59 AM
  5. plasma table retrofit: smart servos or closed loop steppers?
    By Josh Leber in forum Waterjet General Topics
    Last Post: 03-25-2006, 04:25 AM
