585,591 active members*
2,932 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Opening DXF/DWG from Windows
    Feb 2017
    New here and have NO SurfCam experience. I am a SolidWorks user for our CAD files and we are implementing a PDM system and running into a slight issue.
    It seems like there is a different procedure that SurfCam uses when opening dxf/dwg through SurfCam itself vs double clicking from Windows Explorer.
    Is there any way to default SurfCam to open dxf/dwg with the AutoCad Conversion import tool that comes up when I go through SurfCam itself?
    Thanks!
    Sep 2008
    140
    Re: Opening DXF/DWG from Windows
    If the AutoCad Conversion import tool has an .exe extension, you might be able to 'right click' on a DXF/DWG and 'Open With'
    select the AutoCad Conversion import tool, and always open with this program.
    Just a thought.
    Larry
    Feb 2017
    I gave that a shot but it doesn't seem to do anything. They have an application called "GetSettings" that brings up the conversion dialog box. But I'm guessing when you open through File>Open in the background SurfCam is linking the dwg/dxf and the dwg2scrpt.dll with the settings you put in the GetSettings app to actually convert it over.
  1. Job Opening
    By nigjoe in forum Employment Opportunity
    Last Post: 09-20-2011, 02:21 PM
  2. JOB OPENING!!!
    By Pete_Ta1965 in forum Employment Opportunity
    Last Post: 11-30-2010, 02:23 PM
  3. Job opening
    By qnet2 in forum Employment Opportunity
    Last Post: 11-19-2010, 02:10 AM
  4. Job Opening
    By Veridiam in forum Employment Opportunity
    Last Post: 06-23-2010, 04:39 PM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
