586,011 active members*
4,466 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > Build log-drhanger's DM4400 electronics retrofit
Page 5 of 5 345
Results 81 to 97 of 97
  1. #81
    Apr 2010
    125
    Re: Build log-drhanger's DM4400 electronics retrofit
    Marty-
    I was about an inch away from totally giving up on this. I just wasn't getting anywhere, in fact after my initial somewhat successful attempt I was unable to duplicate it and wasn't getting anything at all. Today I went at it again and realized my error--once corrected it works perfectly. Not even an erratic signal, perfectly stable both forward and reverse.
    Next comes working on getting the additional I/O from an auxiliary parallel port, then cut the new circuit board. It's coming together, slowly. Thanks.
    Dan
  2. #82
    Apr 2010
    125
    Quote Originally Posted by Meri View Post
    Just got an old DM4400 but it does not have original power supply under base, actually has no base. Machine sat outside local machine shop for years. I jumped the internal power supply from 240v to 120v and hooked up 120v and the x,y,z axis move fine. The servo amplifier is also missing as is the door. Think it fell off a truck as beat up cabinet.
    Plan on replacing the servo amp with a Bardac 3200i board I have.
    There is a set of wires that ran from the original base power supply #3 on page 7-1 of the original owners manual to the bus bar #5 on page 7-2.
    The white wire on pin 8 is 220v, pin 9 black wire is 110v. Can anyone please tell me what the voltages should be on the other 7 wires?
    Thanks guys.
    Don
    Don-
    Wish I could help out. Like so many others I've gutted almost the entire cabinet for new electronics, so don't even have anything to test measure. Good luck.
    Dan
  3. #83
    Mar 2018
    13
    Thanks Dan,
    Probably have to do the same and replace everything. Did get the brake working so next is install the Bardac board and test the spindle.
    Could you summarize the boards and software you are using. I believe Marty is using the centroid - Acorn setup.
    Don
  4. #84
    Apr 2010
    125
    Don--
    I am using a Leadshine MX3660 for axis motor drivers; I've been pretty happy with it, seems to be reliable and has a small assortment of I/O's available. If your needs are modest it would probably suit you well for this machine. I've also replaced the original steppers and belt drive for a direct drive system. I tried the original steppers for a while but couldn't reliably get more than 72 IPM with that setup, so I made some adapter plates and replaced the motors. I can now get 120 IPM reliably; I've had recent days of using it all day long and have never experienced any lost steps. As for software, I use LinuxCNC. I'm not a Linux expert by any stretch. I built my own CNC router a few years back (my first foray into CNC building after programming and operating for several years) and went with LinuxCNC for the simple reason that it was cheap (open source, no cost) and my son was and is a Linux expert (some would say snob, but, he is my son :-)). In its favor it has a large user community and knowledge base, so if DIY CNC control is your thing I would recommend it. I don't have any experience with any others so can't recommend anything else.
    Dan
    - - - Updated - - -
    Don-
    Where did you find your machine?
  5. #85
    Dec 2009
    521
    Quote Originally Posted by drhanger View Post
    Marty-
    Dan
    So, what did you find the problem was? Please share the error you found.
    BTW, I have an interest in selling mine, with the Flashcut control....
    Marty
  6. #86
    Dec 2009
    521
    Thanks Dan,
    Don
    No,
    My setup is running Flashcut CNC, driving DC Brush Servos. Using the original Servo motor and servo drive. ATC is fully functional. I used the later Air over hydraulic power drawbar.
    If you intend on using the ATC, you need quite a bit of I/O
    Marty
  7. #87
    Mar 2018
    13
    Thanks Dan.
    Machine was abandoned outside a local machine shop for years so I asked and got it. Fortunately as it was going to the metal recycling dumpster the next few days.
    No luck yet with the Bardac spindle driver.
    Looks like the MX4660 is better than the MX3660 with regard to the axis rapid travel. See: https://www.youtube.com/watch?v=Th8IloR_ZBg
    Cheers
    Don
  8. #88
    Dec 2009
    521
    Don, how about a few pictures of the prize?
    Marty
  9. #89
    Mar 2018
    13
    Have the spindle working now with the Bardac 3200i board. Reversed the original mounting brackets for the servo drive, added an al backing plate to mount the board, a type D GE 6 amp circuit breaker, a switch and a potentiometer. The board needs up to 10v on termainal 66 and 68 which I supplied via the pot and a 9v battery. This controls the spindle speed for testing. However a switch is still required to activate, placed between terminals Run and Com. I wired the brake directly to 110v. The Bardac board has 240vac in and 180v dc out which goes through the original iso transformer bottom right of cabinet and also still drives the original amp meter on front of machine.
    Attached Thumbnails Attached Thumbnails Dyna-Mite-4400-mill.jpg   IMG_0224.jpg
  10. #90
    Dec 2009
    521
    Looks like the important stuff is there. Good luck with it!
    ATC is driven by a stepper motor, leave it and reuse it. Many get the machine going but few get the ATC going again.
    If you can come up with an air cylinder for the power drawbar with sensors, and an air cylinder to swing the ATC in and out, again with sensors you would have it licked. There are two sensors on the spindle,one spindle orient and the other is an RPM sensor I believe.
    This machine could do rigid tapping with the skip control.
    Best of luck to you and Dan with your projects.
    Marty
  11. #91
    Mar 2018
    13
    Hi Tim,
    Have you any progress on this such as using the original limit switches? Do you have any part numbers, links to where to get etc.
    Don
    Quote Originally Posted by 2ferrous View Post
    Here is a wiring diagram for operating the presser bar outside of the original controls.
    You reuse the red and green buttons but will need a new capacitor and two DPDT 12vdc relays.
    The limit switches are NOT wired in so it will be easy to over shoot and jam the presser bar.
    Sorry for the poor picture quality. I''ll see if I can make a nice one in the next few days...
    Timothy
  12. #92
    Apr 2010
    125
    Dang, I haven't been getting any notifications from this thread since my last post a month ago, only logged on again because I had another question about the inverter circuit. I have a little catching up to do....
    Don--I may be able to help with the presser bar circuit, I made some mods with a single button in place of the original two buttons on the head for the tool change. If I get some time soon I'll post some pix and diagrams. Mine's a bit simpler than Timothy's but it also involved making a new cam plate for the presser and two limit switches. When I first set up the machine I had removed the presser motor system completely and replaced it with an air cylinder for manual tool changing. After some time I realized that the Belleville washers for the drawbar were worn out and needed replacing (many of them were broken). After replacing them the force required to operate it was beyond the air cylinder's ability, so I went back to the original motor and made the mods to it. It wouldn't work if you plan to get the ATC working though.
    Marty--you asked about the problem I had that I corrected--after a month I've almost forgotten, but it was just simply not connecting the -12V correctly. But I do have another issue I hope you may be able to help with (the reason I logged on today). I just now finally got the circuit board completed and temporarily in place when I ran into a funny issue with it that hadn't shown up before because I hadn't run the speed up fast enough for it to show. Last night I started testing by slowly increasing the spindle speed, when I got up to 3,000 RPM the spindle actually started slowing down with each bump upwards in speed. The more I increased the speed at the control the slower it went. I started checking the output voltage at the VFD on the MX3660, and it was increasing normally as expected, so I was getting a proper PWM signal out of LinuxCNC and from the MX unit. The only thing left in the train is the inverter circuit you gave me. I must have something wired wrong, but I've been over it several times, comparing mine with yours and can't find anything wrong. I've attached an image of the board I made, maybe you can spot something I've done wrong. There are two relays added to the board, one for enabling the spindle amp and another for passing the +5V signal to the inverter section. Any clues?
    Dan
    Attached Files Attached Files
  13. #93
    Dec 2009
    521
    Dan
    You need to monitor the INPUT voltage into the SERVO DYNAMICS Spindle Drive. See if it is closely linear with the signal coming from your MX3660.
    The circuit is very simple. Outputs 0-10VDC until a +5VDC signal is inputted and then it reverses it. There is more needed to operate the tool changer however. You need the spindle orient signal, the brake, and a fixed voltage to the servo drive to do the spindle orient. That's only half the battle.....
    You should just buy my DM4400 B-)
    Marty
  14. #94
    Apr 2010
    125
    Quote Originally Posted by Marty_Escarcega View Post
    That's just it--the analog voltage at the spindle amp is actually reducing while the voltage at the vfd is increasing. This is the voltage coming out of pin 6 on the IC going to the input pin 2 of the spindle amp. It hits a threshold at about 3000 RPM then the signals start going opposite of each other. So increasing the speed at the control increases the voltage signal at the vfd (as it should) but starts decreasing at the spindle amp, reducing the spindle speed.
    I'm not trying to set up the changer so not sure why you mention that.
    Dan
  15. #95
    Dec 2009
    521
    Sorry Dan, not sure what's going on.
    Marty
  16. #96
    Apr 2010
    125
    Okay Marty, thanks anyway. Did you look at my board and compare it with your design? I'd like to at least rule out something I may have overlooked with it. Appreciate it.
    Dan
  17. #97
    Apr 2010
    125
    Problem solved. Electronics rookie mistake. I had the transistor backwards. I did a little research on transistors before completing this, but didn't spend enough time with it. I made a stupid assumption that the flat would be oriented the same way as your diagram, but the transistors I got were reversed. Once I turned it 180° it worked perfectly. I'm getting full speed on both forward and reverse now.
    Dan
Page 5 of 5 345
  1. Multicam router 3ph retrofit-- ps electronics questions.
    By greenb_60097 in forum CNC Machine Related Electronics
    Last Post: 10-03-2016, 07:33 PM
  2. Help with proposed boss 5 retrofit electronics
    By sohcpwr in forum CNC Machine Related Electronics
    Last Post: 11-22-2015, 02:43 AM
  3. Esab piecemaker 2 electronics retrofit
    By cjsamples in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-28-2015, 03:00 AM
  4. Electronics Enclosure Build
    By BobWarfield in forum Charter Oak Automation Support Forum
    Last Post: 04-08-2009, 03:37 PM
  5. Help with electronics - 1st build
    By wprysock in forum DIY CNC Router Table Machines
    Last Post: 10-29-2008, 04:44 AM
