585,670 active members*
4,297 visitors online*
    Jan 2017
    Mazak Slant Turn 35n mazatrol t32-3
    Hello friends,
    Can somebody help me out, when I try to orient the c axis it doesnt complete the operation and the alarm 39 over amp displays on the screen, the shaft that is connected to an hydraulic valve, the clamp that stops the c axis, when I try to orient the c axis it doesnt unclamp. Need help please.
    Hi
    I just got a ST28N ATC MC from a tech school and your machine is very similar.
    How about keep contact?
    Eduardo- WhatsApp +5511966974533
    Quote Originally Posted by HugoChavez View Post
    Hello friends,
    Jun 2012
    36
    Re: Mazak Slant Turn 35n mazatrol t32-3
    Dear Friend,
    You are not specific in hi-lighting the problem.
    1. When you press the C- AXIS I/O push button you can see the C-AXIS gear engage/dis engage operation.
    Is it happening?
    2.You can check the spindle orientation in MDI mode by typing the command M19 .
    Is it ok?
    3.The C-AXIS clamp function is a synchronization of spindle orientation and C-AXIS orientation.
    If there is any shift in the orientation the gears won't mesh.
    I think your spindle drive is FR-SF.
    Finally have you re-initialised the system and if so please ensure that all the parameters are input properly.
    SHEKAR
    Sep 2020
    Kindly gave me a mill spindle orientation adjust parameter in mazatrol T32
  1. Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1'
    By Haaatschi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2021, 01:33 PM
  2. Mazak Slant turn
    By Tobione in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-03-2017, 04:03 PM
  3. PARAMETER MAZAK SLANT TURN 30 WITH MAZATROL T1
    By tonny2105 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2010, 09:30 PM
  4. MAZAK SLANT TURN-28
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-09-2010, 10:45 AM
  5. MAZAK QUICK SLANT 20N MAZATROL CAm T4
    By jlviloria in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2009, 03:14 PM
